Number of Macro-States w/ 2 6-sided Dice: Formula
  • Thread starter Thread starter Alec Neeson
    Dice
The discussion centers on calculating the number of macro-states when rolling two 6-sided dice, where a macro-state is defined as the sum of the two dice. It is confirmed that there are 11 possible macro-states, ranging from 2 to 12. The formula proposed for determining the number of macro-states is n(q-1) + 1, where n is the number of dice and q is the number of states each die can take. Participants express uncertainty about finding a straightforward formula without listing all possible combinations. The conversation highlights the complexity of deriving a formula for macro-states based on the sums of dice rolls.
Alec Neeson
If there are 2 6-sided dice. What is the formula used to calculate the number of macro-states where a micro state is the sum of the two dice? I know there are 11 macro-states but I was curious if there was a formula for calculating this.
I don't think there is any way to find this out apart from listing all microstates and counting the corresponding macrostates.
Combine 1, 2, 3, 4, 5, 6 with 1, 2, 3, 4, 5, 6. There are 6 x 6= 36 such combinations:
1+ 1= 2, 1+ 2= 3, 1+ 3= 4, 1+ 4= 5, 1+ 5= 5, 1+ 6= 7.
2+ 1= 3, 2+ 2= 4, 2+ 3= 5, 2+ 4= 6, 2+ 5= 7, 2+ 6= 8. etc.
Can you confirm that I am right in thinking that there can be no way of knowing how many combinations will add to a certain number without actually listing them all (or some variant thereof).
microstates = q^n, where q = number of states the dice can be in, and n = number of dice
Totally not sure about this, but if we're assuming that dice are always numbered using integers starting at 1 and moving upward sequentially, and label each macrostate with its dice-sum, it seems like it will always be true that the smallest (as it were) macrostate would be n, and the largest macrostate would be q*n. It would also seem true that every integer between n and q*n would also be a legitimately possible macrostate given the integer assumption. If so, the number of possible macrostates in a dice setup could be stated as n(q-1) +1. (edit for the +1)
Disclaimer: Just getting back into thinking and have grown pretty stupid in the last several years.
Yeah that seems to work! Thank you so much.
What makes you think that would be true?
I don't see an easy formula off the top of my head, but I'd be awfully surprised if there wasn't a somewhat elegant way to phrase it.
But maybe you're seeing something that makes you think it's not possible?
Don't have the notebook in front of me, but I did a 5^3 in the passenger seat and I think it went:
1, 3, 6, 10, 15, 18, 19, 18, 15, 10, 6, 3, 1
Somewhat interesting to note, if all 3 sites(n) rolled unique states(q), there are 6 combos; if one duplicate, 3; if triplets, 1. Didn't do a n=4, but if it scales formulaically...
Yesssssss
