MHB Number of multiplications and divisions for LU decomposition
  • Thread starter Thread starter mathmari
    Decomposition
The discussion centers on determining the number of multiplications and divisions required for the LU decomposition of a modified matrix formed by adding a vector to an existing matrix. It is established that to eliminate terms below the main diagonal, one needs approximately n divisions and n multiplications for each entry in the last row of the new matrix, leading to a total of O(n^2) operations. The participants also clarify the correct usage of the vectors involved, correcting a typo regarding the notation. Ultimately, they conclude that their findings support the assertion that the LU decomposition of the modified matrix operates within the complexity of O(n^2). The conversation emphasizes the importance of accurately defining the components of the matrix to ensure the validity of the proof.
mathmari
MHB
Hey! 😊
Let $A$ a $n\times n$ matrix with known LU decomposition, let $u\in \mathbb{R}^n, v\in \mathbb{R}^{n+1}$.
Show that the number of multiplications and divisions that are needed to get a LU decomposition of the $(n+1)\times (n+1)$ matrix $$\begin{pmatrix}A & u \\ v^T\end{pmatrix}$$ is at most $O(n^2)$.
To get $U$, we have to eliminate $n$ terms below the main diagonal (which is the elements of $u^T$ except the last element of that row). Each elimination requires computing the row multiplier, which involves division by the pivotal element.
So we have $n$ divisions, or not? :unsure:
Mathematics news on Phys.org
Hey mathmari!
Yep.
That leaves counting the number of multiplications that we need for each elimination, doesn't it? 🤔
So for each element except the $(n+1)$th one of the last row we have to multiply the row multiplier with the respective row and subtract it from the last row, right?
Therefore we have to do $n$ multiplications, or not? :unsure:
That sounds about right to find a single unknown entry, although a number of those multiplications are actually with zero.
Either way, for the worst case entry in row $n+1$ and column $n$ of the new $L$ matrix, we have indeed $n$ multiplications and $1$ division. 🤔
We still need to repeat for every entry in the extra row below the given L matrix, don't we?
And also for the extra column to the right of the given U matrix? 🤔
I got stuk right now. Could you explain that further to me? I haven't really understood that. :unsure:
We want to find that the order of complexity is $O(n^2)$ don't we?
To find that, we need an algorithm to find the LU-decomposition of the matrix, don't we? 🤔
Let $A=L\cdot U$ be the given LU-decomposition of $A$.
Let $\tilde A=\begin{pmatrix}A & u \\ u^T\end{pmatrix}$ be the matrix to decompose.
And let $\tilde L,\,\tilde U$ be its LU-decomposition.
Can we write $\tilde L,\,\tilde U$ in terms of $L$, $U$, and $u$? (Wondering)
We have that $$\tilde{L}=\begin{pmatrix}L\\ 0 & 0 & \ldots & 0& \ell\end{pmatrix}$$ with $\ell>0$, or not? :unsure:
I don't think so. (Shake)
If it would be, wouldn't we get that $u_1$ is always zero? (Worried)
I got stuck right now. Why is $u_1$ always zero then? :unsure:
What do we get if we calculate:
$$\tilde{L} \cdot \tilde U =\begin{pmatrix}
& \\ & \\ L\\ 0 & \ldots & 0& \ell
\end{pmatrix}\cdot \begin{pmatrix}
&&U& * \\ &&& \vdots \\ &&& *
\\ 0 & \ldots & 0& *
\end{pmatrix}$$
In particular for the entry in the bottom left corner? (Wondering)
Can it be equal to
$$\tilde A=\begin{pmatrix}A & u \\ u^T\end{pmatrix}$$
with $u_1\ne 0$? 🤔
\end{pmatrix}$$
Can it be equal to
with $u_1\ne 0$? 🤔
We have the following, or not?
& & & 0\\ & & & 0\\ L & & & \vdots\\ \ell_1 & \ldots & \ell_n& \ell_{n+1}
&&U& u_1 \\ &&& \vdots \\ &&& u_n
\\ 0 & \ldots & 0& u_{n+1}
\end{pmatrix}=\begin{pmatrix}
&&A& \ell_{11}u_1 \\ &&& \vdots \\ &&& \displaystyle{\sum_{i=1}^n\ell_{ni}u_i }
\\ \ell_1u_{11} & \ldots & \displaystyle{\sum_{i=1}^n\ell_iu_{in}} & \displaystyle{\sum_{i=1}^{n+1}\ell_iu_i}
\end{pmatrix}$$
where $L=(\ell_{ij})_{i,j\in \{1, 2, \ldots , n\}}$ and $U=(u_{ij})_{i,j\in \{1, 2, \ldots , n\}}$.
:unsure:
\end{pmatrix}$$
Yep. (Nod)
It's a bit problematic to introduce $u_1,\ldots,u_{n+1}$ here though.
Doesn't that clash with the given vector $u$? (Worried)
Anyway, we would get that for instance $\ell_1 u_{11}$ must be equal to the first entry of the vector $u$, mustn't it?
If that first entry of $u$ is non-zero, then $\ell_1$ cannot be zero can it? 🤔
Ok, it is better to use other letters.
So have:
& & & 0\\ & & & 0\\ L & & & \vdots\\ \alpha_1 & \ldots & \alpha_n& \alpha_{n+1}
&&U& \beta_1 \\ &&& \vdots \\ &&& \beta_n
\\ 0 & \ldots & 0& \beta_{n+1}
&&A& \ell_{11}\beta_1 \\ &&& \vdots \\ &&& \displaystyle{\sum_{i=1}^n\ell_{ni}\beta_i }
\\ \alpha_1u_{11} & \ldots & \displaystyle{\sum_{i=1}^n\alpha_iu_{in}} & \displaystyle{\sum_{i=1}^{n+1}\alpha_i\beta_i}
\end{pmatrix}$$
The result must be of the form $\tilde A=\begin{pmatrix}A & u \\ u^T\end{pmatrix}$, so it must hold \begin{align*}&\ell_{11}\beta_1=\alpha_1u_{11} \\ &\ldots \\ & \displaystyle{\sum_{i=1}^n\ell_{ni}\beta_i }=\displaystyle{\sum_{i=1}^n\alpha_iu_{in}} \end{align*}
What do we get from that? :unsure:
mathmari said:
The result must be of the form $\tilde A=\begin{pmatrix}A & u \\ u^T\end{pmatrix}$, so it must hold \begin{align*}&\ell_{11}\beta_1=\alpha_1u_{11} \\ &\ldots\end{align*}
From the first equation we get $$\ell_{11}\beta_1=\alpha_1u_{11} = u_1 \implies \begin{cases}\alpha_1 = \frac {u_1}{u_{11}} \\ \beta_1=\frac{u_1}{\ell_{11}}\end{cases}$$ don't we? 🤔
I have just noticed a vector $v$ in the problem statement:
Show that the number of multiplications and divisions that are needed to get a LU decomposition of the $(n+1)\times (n+1)$ matrix $$\begin{pmatrix}A & u \\ u^T\end{pmatrix}$$ is at most $O(n^2)$.
Is there a typo?
Shouldn't that $v$ be used somewhere? (Worried)
I have just noticed a vector $v$ in the problem statement:Is there a typo?
Ahh yes, it is a typo. :oops: It should be:
So from $$
\end{pmatrix}$$ what do we get? :unsure:
We can deduce the values of the $\alpha_i$ and $\beta_i$ can't we?
Once we have those, we have the LU-decomposition of $\tilde A$. 🤔
Let $v=(v_1, \ldots , v_{n+1})$ and $u=(x_1, \ldots, x_{n+1})$.
We have that \begin{align*}&\alpha_1u_{11}=v_1 \Rightarrow \alpha_1=\frac{v_1}{u_{11}} \\ &\ldots \\ &\sum_{i=1}^n\alpha_iu_{in}=v_n \Rightarrow \alpha_n=\frac{v_n-\sum_{i=1}^{n-1}\alpha_iu_{in}}{u_{nn}}\\ &\sum_{i=1}^{n+1}\alpha_i\beta_i=v_{n+1}=x_{n+1} \Rightarrow a_{n+1}\beta_{n+1}=v_{n+1}-\sum_{i=1}^{n}\alpha_i\beta_i \ \text{ and } \ a_{n+1}\beta_{n+1}=x_{n+1}-\sum_{i=1}^{n}\alpha_i\beta_i\\ &\ell_{11}\beta_1=x_1 \Rightarrow \beta_i=\frac{x_1}{\ell_{11}} \\ &\ldots \\ &\sum_{i=1}^n\ell_{ni}\beta_i=x_n \Rightarrow \beta_n=\frac{x_n-\sum_{i=1}^{n-1}\beta_i\ell_{ni}}{\ell_{nn}}\end{align*}
Is everything correct? :unsure:
I see an $u_n$ that I think should be a $v_n$.
And I also see an $u_{n+1}$ that should be a $v_{n+1}$. (Worried)
Other than that it looks good to me! (Nod)
I changed it!
So in total we do $\displaystyle{2\cdot \sum_{i=1}^ni=2\cdot \frac{n(n+1)}{2}=n(n+1)}$ mutliplications and $\displaystyle{2n}$ divisions, or not? :unsure:
mathmari said:
I changed it!
Yep. (Nod)
Yep. (Nod)
Great! Is this a formal proof to write the matrices and the formulas that we get? Or do we have to do also something else/more? :unsure:
We have identified an algorithm with order $O(n^2)$ that solves the problem.
So that qualifies as a proof that the order of the desired LU-decomposition is at most $O(n^2)$, doesn't it? 🤔
