Numerical Integration in 3D Space: Fortran 90 Help and Insights | TheIsingGuy
The discussion focuses on integrating a function in 3D space using Fortran 90 and plotting the results for comparison with an analytical solution. The user, TheIsingGuy, successfully integrates the function but seeks guidance on plotting the integrated function. They consider using piecewise integration with trapezoidal approximation to calculate average values. The discussion also references the Numerical Recipes book and NAG libraries as resources for further assistance.
  • Fortran 90 programming
  • Numerical integration techniques, specifically trapezoidal rule
  • 3D plotting libraries compatible with Fortran
  • Understanding of piecewise functions
  • Research 3D plotting libraries for Fortran, such as DISLIN or PLplot
  • Learn about advanced numerical integration methods beyond trapezoidal rule
  • Explore the Numerical Recipes book for additional algorithms and techniques
  • Investigate NAG libraries for optimized numerical routines in Fortran
This discussion is beneficial for Fortran developers, numerical analysts, and researchers working on 3D function integration and visualization.
TheIsingGuy
I want to integrate a function in 3D space, and then plot the integrated function, to compare with my analytical solution, I am using Fortran 90, I have no problem integrating, I am just not sure how I can plot the resulting function out. I am currently thinking about piecewise integration, using small intervals with only 1 trapezium, where I take each trapezium, find its area and divide by dx(its height) to give the average value of the 2 bases, which I am approximating as the value of the function.
I would be grateful if someone could share some insights on this problem.
must appreciated. TheIsingGuy
CFDFEAGURU said:
You should visit the following site.
http://www.nrbook.com/a/bookf90pdf.php
Hope this helps.
Thanks. I have figured it out anyways. I already knew about the recipes book and NAG libraries but what I had in about 8 lines of code it took them about 2 pages...
