Object and Friction on the object
  • Level: High School
  • Thread starter Thread starter dexter90
    Friction
8 replies · 2K views
dexter90
Good Morning
I am new user on Forum and I'm sorry for all mistake. I am living in Poland and My English is on the low level.
My question concers friction on the objects. We have formula:
[tex]T=μ \cdot N[/tex], where
[tex]μ[/tex] - coefficient on fraction
[tex]N=m\cdot g[/tex]
and formula:
[tex]F=m\cdot a[/tex]
I think that:
[tex]F=T \Rightarrow m\cdot a=μ \cdot m\cdot g[/tex]
This is true?? Coefficient [tex]m[/tex] is mass object?? If on the object interacts more physical force ( example Friction's ) = [tex]m \cdot a=m\cdot μ\cdot (N_{1}+N_{2}+...+N_{n})[/tex]??
I greet
welcome to pf!
good morning, dexter90! welcome to pf! :smile:
dexter90 said:
I think that: [itex]F=T \Rightarrow m\cdot a=μ \cdot m\cdot g[/itex]
This is true?? Coefficient [itex]m[/itex] is mass object?? If on the object interacts more physical force ( example Friction's ) = [itex]m \cdot a=m\cdot μ\cdot (N_{1}+N_{2}+...+N_{n})[/itex]??
(btw, we usually write "T" only for "tension" :wink:)
one object only has one normal force (N), and one friction force (µN) with a particular surface
for example, if a rope with tension T is pulling an object with mass m along a horizontal surface, then the F = ma equation is:
T - µmg = ma :wink:
(your equation ma = µmg is impossible … if the only force is friction, then the object won't move!)
Thanks you for quickly answer.
I understand, one object -> one force ( friction on the surface ). Friction is force which retard object. If on the object interacts more force's then coefficient retard is bigger, example: air resistance, then We have from formula:
[tex]m\cdot a=m\cdot g\cdot μ[/tex], next
[tex]a=g\cdot μ + \lambda[/tex], where:
[tex]\lambda[/tex] - coefficient air resistance in [N].
Yes?
I greet.
hi dexter90! :smile:
dexter90 said:
… If on the object interacts more force's then coefficient retard is bigger, example: air resistance, then We have from formula:
Yes?
not exactly …
air resistance is not proportional to mass (it's proportional to cross-section area, and it also depends on speed, but not mass, see http://en.wikipedia.org/wiki/Drag_equation),
so the equation will be something like -ma = µmg + kAv2,
or a = -(µg + kAv2/m) :wink:
I have a question to this formula:
[tex]-ma...[/tex]
Not exist [tex]-[/tex] in [tex]ma=μmg[/tex]. Now, it is present because force air resistance is returned in the opposite direction??
I apologize for the grammar :)
both the friction and the air resistance are retarding forces (they both reduce the acceleration of a moving object)
so it should have been -ma = µmg
