Object designed with low entropy
  • Context: Undergrad
  • Thread starter Thread starter ryanluke86
    Entropy
2 replies · 2K views
ryanluke86
Hi,
I watched 'Wonders of the Solar System' by Prof. Brian cox last night on BBC2. In it he talks about entropy, from which I had a question.
Can an object be purposely designed in a way that entropy increases more slowly. I am thinking in terms of the shape of the object rather than the material or structure.
If we take a square object and a circular object for example. Both are made of the exact same material and are perfectly the same apart from their shape.
If both objects were left for x amount of time, would the square object have more entropy than the circular one, just because of its shape?
If this is the case, if an object was to be designed to last many thousands of years for whatever reason, the best design would be for it to be as rounded or circular as possible.
Entropy isn't shape dependent,nor are other thermodynamic properties
Perhaps you should first learn what entropy is. The question makes no sense, sorry.
I blame it on these "layman terms educators" who try to simply explain entropy. You either get it or you don't, its that kind of concept, you can't just "have an idea" of what it is, that is totally useless.
Entropy is the uncertainty of a system's microstate. Almost always, changes in entropy are important, which is equivalent to loss of information. That's all it is.
