Objective-C Help - Ignacio Cabero Can't Figure It Out
  • Thread starter Thread starter ignaciocabero
The discussion revolves around troubleshooting issues in Objective-C code, specifically related to syntax errors and compiler messages. Participants are seeking assistance with understanding and resolving these coding problems.
  • Homework-related
  • Ignacio Cabero expresses frustration in resolving a coding issue and requests help.
  • One participant notes a potential syntax error in the code snippet involving brackets, suggesting that every "[" should have a matching "]".
  • Ignacio acknowledges that the advice helped with one issue but indicates there are still three other problems to address.
  • Another participant provides hints about error handling, mentioning that fixing the first error might resolve subsequent ones and that errors may be caused by issues in preceding lines.
  • Ignacio reports that attempts to follow the advice regarding parentheses did not resolve the issue.
Participants do not appear to reach a consensus, as there are ongoing issues and multiple perspectives on the nature of the errors in the code.
There are indications of missing assumptions regarding the specific errors and the context of the code being discussed. The discussion reflects uncertainty about the correct syntax and the compiler's feedback.
Individuals learning Objective-C, those troubleshooting similar coding issues, or participants interested in syntax error resolution in programming.
ignaciocabero
I've tried to figure out the problem all night, but I can't figure it out.
Sorry if it's hard to see.
Thank you so much,
Ignacio Cabero.
Technology news on Phys.org
I've never used Objective-C, but even I can see there's something wrong with
Code:
         [[hero addChild:rightEye];
I'm pretty sure every "[" needs to be matched by a "]".
Thanks so much, that helped for the hero addChild, but there is still the three other ones that I need help with (the ones under the hero addChild
Welp, I actually fixed that problem by adding some brackets, but now this shows up.
ignaciocabero said:
Welp, I actually fixed that problem by adding some brackets, but now this shows up. View attachment 72194
Some hints about errors.
  1. When one error occurs, often the following lines don't make sense to the compiler; fixing the first error may make the other errors go away.
  2. Sometimes the error isn't on the line identified by the compiler, but on the line before (e.g. something is missing from the line before, so the compiler can't make sense of the current line).
That second hint applies to the error you have now.
Thanks, but when I put a '( ' like it tells me to, it doesn't work.
  • · Replies 19 ·
