ODE Change of Vars: Techniques for Bessel Function Transformation
In summary, the conversation discusses solving an ODE using a change of variables technique and the use of Mathematica to find the solution in terms of Bessel functions. The questioner uses this "cheating" method in their research and asks about the technique behind the change of variables. The responder provides the method they use and shares their Mathematica code for solving the equation. The questioner thanks them and mentions their interest in high energy and plasma physics.
robousy
334
Hey,
I'm reading the paper:
http://arxiv.org/abs/hep-ph/9907218
They have an ODE (eqn 7):
[tex]-\frac{1}{r^2}\frac{d}{d\phi}e^{-4kr\phi}\frac{dy_n}{d\phi}+m^2e^{-4kr\phi}y_n=m^2_ne^{-2kr\phi}y_n[/tex]
They then make a change of variables:
[tex]z_n=\frac{m_n}{k}e^{kr\phi}[/tex]
[tex]f_n=e^{-2kr\phi}y_n[/tex]
Then the ODE becomes:
[tex]z_n^2\frac{d^2f_n}{dz_n^2}+z_n\frac{df_n}{dz_n}+(z_n^2-[4+\frac{m^2}{k^2}])f_n=0[/tex]
My question is regarding this change of variables:
How do you 'know' how to change the variables so that the ODE comes out as this tiday Bessel function. Is this an art almost, or is there some kind of technique??
Looking foward to gaining some insight here.
Richard
I use the following "cheating" technique in my research:
Solve the equation in Mathematica. Look at the arguments of Bessel function etc that is gives and make the necessary substitutions :)
This method works for your equation, Mathematica 6 gives the solution (f_n) in terms of BesselJ functions of the argument (z_n).
Nice. I like it. I like it a lot. Thanks avalonme. I'll try it first thing tomorrow. Its been bugging me for about a week now.
Rich
say, did you try this avalonme? Also do you use DSolve? I plugged in the above formula and get exponential solutions, not the bessel function soltn I was expecting.
That's what I did: you can directly copy this to Mathematica 6.
Cell[CellGroupData[{Cell[BoxData[
RowBox[{
RowBox[{"DSolve", "[",
RowBox[{
RowBox[{
RowBox[{
RowBox[{
RowBox[{"-",
FractionBox["1",
SuperscriptBox["r", "2"]]}],
RowBox[{"D", "[",
RowBox[{
RowBox[{
RowBox[{"Exp", "[",
RowBox[{
RowBox[{"-", "4"}], "k", " ", "r", " ", "\[Phi]"}], "]"}],
RowBox[{
RowBox[{"y", "'"}], "[", "\[Phi]", "]"}]}], ",",
"\[Phi]"}], "]"}]}], "+",
RowBox[{
SuperscriptBox["m", "2"],
RowBox[{"Exp", "[",
RowBox[{
RowBox[{"y", "[", "\[Phi]", "]"}]}]}], "\[Equal]",
RowBox[{
SuperscriptBox["mn", "2"],
RowBox[{"Exp", "[",
RowBox[{
RowBox[{"-", "2"}], " ", "k", " ", "r", " ", "\[Phi]"}],
RowBox[{"y", "[", "\[Phi]", "]"}]}]}], ",",
RowBox[{"y", "[", "\[Phi]", "]"}], ",", "\[Phi]"}], "]"}], "[",
RowBox[{"[", "1", "]"}], "]"}]], "Input",
CellChangeTimes->{{3.4173143524375*^9, 3.417314453640625*^9}, {
3.417314484921875*^9, 3.417314486453125*^9}}],
Cell[BoxData[
RowBox[{"{",
RowBox[{
RowBox[{"y", "[", "\[Phi]", "]"}], "\[Rule]",
RowBox[{
RowBox[{
SuperscriptBox["\[ExponentialE]",
RowBox[{"2", " ", "k", " ", "r", " ", "\[Phi]"}]], " ",
RowBox[{"BesselJ", "[",
RowBox[{
RowBox[{"-",
FractionBox[
SqrtBox[
RowBox[{
RowBox[{"4", " ",
SuperscriptBox["k", "2"]}], "+",
SuperscriptBox["m", "2"]}]], "k"]}], ",",
FractionBox[
RowBox[{"mn", " ",
SqrtBox[
RowBox[{
SuperscriptBox["r", "2"]}]]}],
RowBox[{"k", " ", "r"}]]}], "]"}], " ",
RowBox[{"C", "[", "1", "]"}], " ",
RowBox[{"Gamma", "[",
RowBox[{"1", "-",
FractionBox[
SqrtBox[
RowBox[{
RowBox[{"4", " ",
SuperscriptBox["m", "2"]}]], "k"]}], "]"}]}], "+",
RowBox[{
RowBox[{
FractionBox[
SqrtBox[
RowBox[{
RowBox[{"4", " ",
SuperscriptBox["m", "2"]}]], "k"], ",",
FractionBox[
RowBox[{"mn", " ",
SqrtBox[
RowBox[{
RowBox[{"C", "[", "2", "]"}], " ",
RowBox[{"1", "+",
FractionBox[
SqrtBox[
RowBox[{
RowBox[{"4", " ",
SuperscriptBox["m", "2"]}]], "k"]}], "]"}]}]}]}],
"}"}]], "Output",
CellChangeTimes->{{3.417314442578125*^9, 3.417314453890625*^9},
3.417314487515625*^9}]
}, Open ]]
Thanks. When I saw the result it put a huge smile on my face! This is great. One extra (and important) piece in a big puzzle I'm trying to put together.
I compared my short code against yours and the only difference was that I took the derivative of the first term in the expression by hand before putting into mathematica. Hmmmm, I thought I could differentiate...
Incidently I checked out your homepage. I'm in high energy at Baylor in Texas, but a guy I share an office with is into Plasma physics. Some nice papers you have out.
Richard
Related to ODE Change of Vars: Techniques for Bessel Function Transformation
What are Bessel functions?
Bessel functions are a type of special functions that arise in many mathematical and physical problems involving circular or cylindrical symmetry. They are named after the mathematician Friedrich Bessel and are used to solve differential equations in various fields.
Why do we need to transform Bessel functions?
ODE Change of Vars: Techniques for Bessel Function Transformation involves transforming Bessel functions into a more manageable form in order to solve differential equations. This is necessary because Bessel functions are not always easy to work with and can be difficult to solve using traditional methods.
What are some common techniques for transforming Bessel functions?
Some common techniques for transforming Bessel functions include the Laplace transform, the Mellin transform, and the Fourier transform. These transformations can help simplify the equations involving Bessel functions and make them easier to solve.
What types of problems can be solved using Bessel function transformation?
Bessel function transformation can be used to solve problems in many fields, including physics, engineering, and mathematics. Some common applications include solving heat conduction problems, wave equations, and oscillatory systems.
Are there any limitations or drawbacks to using Bessel function transformation?
While Bessel function transformation can be a powerful tool for solving certain types of problems, it is not always applicable. Some equations involving Bessel functions may not be amenable to transformation, and in some cases, the transformed equations may be more complex than the original ones. Additionally, care must be taken when choosing the appropriate transformation, as different techniques may yield different solutions.
  • Differential Equations
  • High Energy, Nuclear, Particle Physics
10K
