What force should be used to calculate Young's Modulus?
The discussion centers on calculating Young's Modulus for a rod subjected to varying forces, specifically f Newtons at one end and 2f Newtons at the other. Participants clarify that the tensile stress varies along the length of the rod, necessitating calculus for accurate elongation calculations. The consensus is that the average force used in calculations should be 1.5f, as it represents the mean of the applied forces. The conversation emphasizes the importance of understanding tensile stress distribution and the need for integration in solving such problems.
  • Understanding of Young's Modulus and its significance in material science.
  • Familiarity with tensile stress and its calculation methods.
  • Basic knowledge of calculus for integration and differential equations.
  • Awareness of Newton's laws of motion and their application in mechanics.
  • Study the derivation and application of Young's Modulus in various materials.
  • Learn about tensile stress distribution in non-uniformly loaded rods.
  • Explore calculus techniques for solving problems in mechanics of materials.
  • Review examples of similar problems in mechanics textbooks, such as Hibbeler's.
Students and professionals in engineering, particularly those focused on materials science, mechanics, and structural analysis, will benefit from this discussion.
gianeshwar
If a rod with cross section area A and length L is lying on a smooth table with one end being pulled by f Newtons and other end by 2f Newtons.
What force I can use in calculating Young's Modulus and why?
my doubt is whether it will be 3N or 1.5N and why?
Stretched length is given.
It will be accelerated by a = F/m, not sitting still on the table, no?
Thanks! I want to know value of force i.e., 1.5f or 3f.
Then how can I calculate Young's modulus only under these given conditions.
There is no physical condition with stable object by non zero external force. If I understand your problem.
I need to find tensile stress on rod as I want to find elongation for calculating young's modulus
The tensile stress will vary throughout the length of the rod...density & some calculus is needed.
Have you done any elongation or stress of a rotating rod type questions? This are similar.
According to my understanding so far rod is moving here with acceleration (2f-f) /m and it is also stretched having tensile stress f/2.
Thanks billy! I have not done many problems as you asked.
Stating same problem in a different wayhttps://mmi240.whatsapp.net/d/yywezFW6TcxsIWacjmME81VjKfY/AunnYXfkq2P8Blmy__wJQyRLQ4aL4z8kQXlZUs2wGVPB.jpg
https://mmi130.whatsapp.net/d/l-CffzhTrS1R5PpPeDk30FVjLnU/Ard1QFFL7XB255nzwRl_0yw8Xxy2I-ChbVHnl1qLgWAY.jpg
No, as was stated earlier, you need to take into account that the tension varies throughout the rod.
Then here in new case answer is F?
No.
Imagine accelerating a long chain by pulling one end. Where is the chain most likely to break?
The first link must support every other link. The last link supports only it's own self weight. Therefore, the stress & elongation in each link is not the same.
Your problem looks at a chain with an opposing force on the last link.
You need to analyse an infinitesimal section of your bar, set up an integral, find the integration constant from the boundary conditions, perform the integration over the length of the bar. (Or similar, It's been a while for me..)
Every decent mechanics of materials textbook (I found Hibbeler good) will likely have multiple examples of the very similar rotating bar situation.
Likes gianeshwar
Thanks!Why are you saying "very similar rotating bar". Specifically rotating.
Also I want to know whether my question has a simple answer or the question is not complete or the question is irrelevant...(restated question)
They are very similar because they are analysed in a similar way.
http://www.mathalino.com/reviewer/m...als/solution-to-problem-218-axial-deformation
and exe 1.296 here
http://exir.ru/solutions/Elastic_Deformations_of_Solid_Body.htm
There is enough information given to reach a meaningful answer. Whether it's simple or not would depend on the student.
Thank you billy!
  • · Replies 23 ·
21K
28K
11K
