One pin AC connector (Coaxial)
31 replies · 6K views
Algr
TL;DR
Coaxial plug/socket for line level power with an extra pin for data or DC.
I was reading about someone building a DC house, because this would make solar+battery more efficient. I was wondering what those plugs would look like, but found that there didn't seem to be any standard for DC 120v plugs and sockets. So I thought I'd try to make one, just for kicks:
This is based loosely on the 12v coaxial cable that most AC/DC adapters use. I figured that for 15A it would need to be bigger. It has four pins and so can carry both AC and DC, or 120v and 240v, or maybe AC and data. In the latter case, I'd figured the inner pin would be hot, while starting from the tip would be neutral, data, and ground. That way any foreign object being inserted in the plug would touch ground before anything else.
Those 12v coaxial connectors can rotate in their sockets. I figured that would be bad at 15 amps, so I made it square instead of round. It still inserts four ways. Any thoughts?
It is standard practice these days for the ground connection to be made first and broken last when HV connectors are inserted or removed. This is in most safety standards.
Also, it looks kind of expensive, but IDK.
When you insert it, the ground would momentarily touch the neutral and the data pin before grounding the device, but would still connect before the hot wire. (So maybe the pin closest to the handle ought to cary data instead?). For clarity, I drew the internal metal visible in the hole, but it perhaps ought to be further back to assure it connects last.
This shouldn't cost much more than a headphone jack to manufacture. It doesn't need to be copper, the image just came out that way.
I'm presuming that the data pin isn't competing with ethernet, but is for USB 2 speeds. This is good for authentication and security, since physical access is necessary to connect to the network. The main thing I don't know how to calculate is if this will cary 15A safely.
Would the jack for it be big enough to admit the finger of a toddler? I see ground would be outermost, but that could still result in a nasty injury. It also looks like something conductive inserted in there could short several circuits together.
As you insert the connector, different circuits of the load would contact the wrong pins, no?
It looks too easy to come into contact with live pins as the connector is pulled out (mind you, so does the one on the left). Being a sequential connector, it would be hard to solve that with sleeved pins.
No fuse(s)? Coming from the UK where they’re standard, I might be biased, but does it not make sense to protect the appliance flex from setting on fire?
It's about the size of a 1/4" headphone jack, so a toddler's finger would not fit. Also, the tip of the hot pin inside the socket (not shown) would be non-conductive. A fuse could be added by making the handle a bit larger. We have these in the US, but I've only ever seen them on christmas light strings. Since the plug is polarized, only one would be needed.
Would it be big enough for 15A conductors?
Again, thinking through the sequential connection, when inserting the jack you would briefly connect N and ground. This could trip an RCD (GFCI) and rule out the design in the UK and EU.
In the USA low voltage wiring such as data, speaker wires, etc are not allowed to run in the same conduit and eventually receptacle box as the 120 volt power wiring.
A child could insert a metal object. Why not have a shutter to close the live terminal, as in the UK plug system?
Current code in the USA requires pretty much every receptacle to be tamper proof as @tech99 described.
If you are serious about having input to develop a standard you need to be more informed. If this is just for fun, then I guess we'll just keep going as we are here.
I know it has been tossed around for a while about using DC at higher voltages as described in this thread. It's a bad idea to me. Here's one reason: https://www.physicsforums.com/threa...cts-causes-and-solutions.880861/#post-5535189
I think there must be more to this jack than it appears. Those conductors are going to wipe across other (the wrong) conductors as the jack is inserted. IMO, the live and neutral in the receptacle must be lifted away from the rings on the jack or the could be an Earth-Neutral contact on the way in as the Load L and N go past the supply N and Earth. That would trip an RCD (above).
I guess I'm just re-stating the "shutter" word but the L and N should not be available till the jack is sitting snugly in position. Perhaps the hole down the centre could locate round a pin to make the mechanism work.
The house engineer where I worked showed me a British Standard finger
  • Haha
Uh oh. I was aware of the contact, but didn't know it was a problem. Back to work, I guess.
I guess that is why home ethernet never took off? There are networks that use the AC wires themselves to transmit data, so presumably if a networking standard is designed to be run this way, it would have protections. Does this apply to 12v power? Is there some danger of leakage or hot-to-hot contact?
I was thinking of the ground contact as being the shutter - a foreign object can't touch hot without also touching ground. But if the ground can't contact the neutral, then that will have to be different.
I was seeing this thread as testing my knowledge, and seeing what I need to learn. I'm not expecting to propose this in congress tomorrow.
Yikes! Maybe that DC house was all 12/24 volts? It could have been using appliances made for boats and RVs. But standard house wiring would transmit a lot less power. Vacuum cleaners and hair dryers will always need 120v, so it looks like AC isn't going away any time soon.
sophiecentaur said:
I think there must be more to this jack than it appears. Those conductors are going to wipe across other (the wrong) conductors as the jack is inserted. IMO, the live and neutral in the receptacle must be lifted away from the rings on the jack.
Yes, that is a good idea. I was worried about how close the neutral and hot pins in the socket would have to be to each other, and if there was risk of them making contact when no plug was inserted.
Great! That's what this forum is for. Refreshing change from those who come here to argue that they can, or already have, broken the laws of physics. Or to claim they are above safety.
  • Haha
The NEC is very concerned about keeping 'everyone else's business' out of the equipment that the rules of the NEC govern. In other words, nothing can share a conduit or technically even be zip tied to a conduit. This begins at the meter and ends at the receptacle. NEC has no say in what you plug into an outlet. Local fire codes may. Many things today are sold on Amazon that are made to plug into a standard 120 volt outlet that should never be used. They are never UL listed but the NEC has no say. NEC also has no say in the wiring leading to your house prior to the meter. Their wiring (power company) is often several sizes smaller than what is between your meter and the breaker panel. Each job is evaluated by an engineer. The wiring after your meter and in your house is not.
While we are dreaming of a new type of connector that plugs into the wall for power I would make it triangular and keyed so it's impossible to plug in 120 degrees off. A contact on each side arranged so a specific order is achieved upon plugging in as to what makes contact first. Flipper door(s) could be utilized for safety against curious fingers.
In all honesty though, I like what we have now.
Lots if interesting info, thank you!
I see how this makes sense for Ethernet and RJ-11, since these standards were not built with this situation in mind. But a standard designed from the start to integrate data with power ought to be safe, as all the products would be built with shields to prevent the foreseeable problems. Perhaps data and 12v DC could share the same pin. As I said above, it needn't be as fast as Ethernet, it is for convenience and security.
I'm finding these products on the net:
I have the first one in my home. I presume this is okay because the USB only provides power and not data? I asked Amazon's AI if the second one was legal in the US, and it said "Check local regulations."
Sadly, no standard is going to stop people from cutting corners, unless the standard can be enforced.
That is the opposite of what I had in mind. Having to rotate the plug all over to find the right orientation can be a real pain in cramped situations. I designed it so orientation is irrelevant, like in headphone jacks and the EIAJ connector.
I am indeed above safety, but then I trip and fall on the safety and damage it. Ouch!
Agreed. Is there another way to maintain order of contact without excessive complexity? I can see a peg in the end of the plug that would activate all of the contacts at the last moment. Reliability, size and complexity becomes an issue. A triangular plug with redundant contacts all around would be closer but still require lining up. Three contacts on each side for hot, neutral and ground in the receptacle. But only one on each side of the plug. No matter how it's shoved in the correct contacts always line up. Still requires alignment +/- 60°.
Could have a center peg for ground in the receptacle that goes up the center of the plug and sleeve and tip with the sleeve being larger on the plug. This could satisfy the order of contact and prevent contacts matting that are not supposed to. Reliability could be an issue. It's not likely to be adopted for AC to replace what we have. Higher voltage DC is unlikely to be utilized due to the issue of extinguishing the arc on switch contacts. Low voltage would be fine but it's not likely necessary to require a third wire for ground when the dc voltage gets low enough to be considered safe concerning switch arcing. Still, it never ceases to amaze me the number of various connector types that exist.
Here we go. I'm not sure if these areas are properly called "rings" when the plug is not round, but this is the term I found in my search.
We can prevent the rings from connecting ground and neutral together by having the insulation rings bulge outward from the pin. That way when the plug is inserted, the pins are pushed away from either ring when they might contact more than one. The hot contact is the last to connect, because the plug has to be fully inserted for that pin (Built into the plug) to get over the insulator.
Copper color indicates the plug, grey is the socket. The hot contact is shown twice for clarity, and is actually inside the rings.
^ That might do it. Only concern is long-term wear of the plastic insulation rings being rubbed against metal pins.
The problems of child safety, order of contact and DC arcs could be solved by fitting the socket with an interlocked switch - only closable when a plug is inserted, and locks the plug in place until opened.
Could be. A wider right with a more gentle bulge would allow thousands of inserts before wearing out. Also, these bulges provide some resistance to the plug pulling out, so that the pins don't need to apply too much friction. Is there a safety issue with making a plug too difficult to remove? In an emergency, being able to yank the plug out quickly would be good.
The UK style mandatory switches on every socket always bothered me. Important devices like computers or medical equipment could be accidentally switched off too easily by objects falling behind a desk - and could be very hard to reach behind to reactivate.
Not as far as I know. In an industrial setup over here, you’ll see round ‘Ceeform’ plugs for 16 or 32 A outlets, or three phase:
They don’t have to be switched - unplugging is seen as a suitable isolation method - but can be very stiff to pull out.
This sounds unlikely - they’re rocker switches, rocking ‘upwards’ to switch off. I can’t see how dropping something from above would do this. Perhaps @sophiecentaur has seen such an event, being longer in the tooth than me?
Pets.
I think most US houses have 2 phase, not three phase. That is why the Tesla charging port works like it does.
Just a thought: The 12v network is NOT connected to the internet by default. Each device has to manually ask your router for access, and then the homeowner decides to allow or deny it. Or allow for 24hrs only. No more mysterious "updates" that brick your fax/scanner because some sponge is too old.
I never had my life support cut off by a falling object.
I just move into an 'aged' house and the polarity of rocker light switches varied from place to place even in the same room . Switched mains sockets are (obvs) single throw (up/OFF down/ON and the earth pin/hole is always at the top so there should be no confusion there,
Vital equipment should always have something better than a simple rocker switch.
Those EU connectors (referred to as Mothercare plugs, where I worked) and look much the same for Three,Single phase and for 12v Auto use. Problem with them is they stick out a long way and are vulnerable to passing fork-lift trucks. A real struggle to unplug if space is restricted. Natch, it would have been impossible to get approval for UK 13A connectors to be accepted anywhere else but 'here'.
Well if you did, you wouldn't be here talking about it.
Now I've got 120/240 volts in mind. This is actually more complex than it sounds. You can't just add an extra pin and connector, because universal devices would have to connect to both, adding complexity.
Do 240v devices get damaged if you give them 120v?
In the USA 240 volt devices utilize two separate 120 volt conductors. Each one is 120 volts to ground and neutral and 240 volts between them.
I'm a hard man; I would have held my breath long enough till the nurse cam in.
I guess half volts could lead to a motor stalling and that could be bad news. But electronic power supplies are fairly forgiving these days.
I remember trying to shave on a visit to US. The oscillations of the blade were pretty feeble with only 120V.
Some might (esp. motors), others will be OK. Many will be unknown because the designers don't design for or test things you aren't supposed to do.
I could have sworn that I saw somewhere an electrical connector that works like a key. You stick it in, but electrical contact doesn't happen until you rotate it 90°. (Which also prevents it from being yanked out.). I can't find any sign of this now. Does anyone know what this is/was?
There are a number of bayonet connectors, used for RF coax. There's a 'C' version of the popular threaded type 'N'. C is a bayonet connection and they are rated at 8kV. Fiddly to assemble, compared with 50Hz circuits but the locking
mechanism is there. Bigger systems are available for higher powers but the centre conductor would handle reasonable current levels. One snag that strikes me is the fact that the centre conductor of Coax is thermally insulated and dissipation could be the final limiting factor to current.
8kV? That is a lot of power down that little pin. I expect that the amperage would not be that high?
It occurs to me that the socket I drew above has a flaw: If the plug is not inserted, the 12v+data pin might touch the hot contact. This flaw also exists in real-life DC coaxial plugs, but since those only carry 12 volts and no data, it might not be such an issue. I suppose I could eliminate this issue by using the internal pin for data and making it longer and shielded so that it would not touch the hot pin.
Or I could eliminate the internal component and just have four external contacts. That would be simpler, but might make the plug too long, or limit how many amps it could cary.
Algr said:
TL;DR: Coaxial plug/socket for line level power with an extra pin for data or DC.
DC power is quite a rabbit hole. For any connection you need to consider arcing (welding kind/intensity) by default, since there are no 'zero crossings', but you have to be ready for plenty of inductive stuff.
