Graduate One way vibrational energy transfer
Yale University researchers have developed a technology that enables sound and heat to flow unidirectionally using a standard cavity-optomechanical interaction. This innovation raises questions about the implications for the laws of thermodynamics, particularly regarding heat transfer and cooling mechanisms. The authors emphasize that breaking reciprocity requires a laser, which introduces work into the system, effectively creating a novel heat pump. While the article does not provide sufficient details to confirm compliance with the second law of thermodynamics, it does not suggest any violations. Overall, this new heat pump technology is likely to adhere to established thermodynamic principles.
vin300
https://www.sciencedaily.com/releases/2019/04/190403135011.htm
Yale University folks have come up with a new technology which they say can make sound as well as heat flow in one direction only. This is done by using a "standard cavity - optomechanical interaction to produce robust nonreciprocal coupling between phononic resonators". The journal reference in given at the bottom of the news article.
If they can control heat flow by turning a knob, what happened to the laws of thermodynamics? I haven't read the full journal article.
The original paper is here:
https://arxiv.org/abs/1807.03484
Note that the arxiv preprint has not yet been updated to reference the Nature article, hopefully they will do that later.
In the article the authors mentioned repeatedly that the breaking of reciprocity requires using a laser. In the section on cooling they mentioned the power of the laser, but not the power of the thermal transfer from one cavity to the other nor the temperatures of the two cavities.
The power of the laser represents work. Therefore the cooling provided here is simply a completely novel type of a heat pump.
As long as: $$\frac{Q}{W}\le \frac{T_C}{T_H-T_C}$$ the device obeys the second law of thermodynamics.
The article does not provide enough information to confirm that it does obey the second law, but it also does not provide any hint of a suggestion that it violates it. This article certainly wouldn’t support any supposition of a violation. In the absence of clear evidence to the contrary it is safe to assume that this new class of heat pump will satisfy the second law of thermodynamics.
Likes anorlunda and vanhees71
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
18K
  • · Replies 45 ·
  • · Replies 16 ·
