Online assignments = confusion
  • Thread starter Thread starter Alana456
    Confusion
Online courses can be challenging due to the lack of direct teacher interaction and peer collaboration. A specific question about determining a quartic function's equation highlights the confusion many face with advanced math topics. The discussion explains that the function has roots at -2, -1, and 3, with the behavior of the function determined by these roots. It emphasizes that the graph does not cross the x-axis at x = -1, indicating it is a double root, which is crucial for constructing the quartic equation. Overall, the conversation reflects the difficulties of understanding complex mathematical concepts in an online learning environment.
Alana456
I'm doing an online course, and am finding it to be extremely difficult to do without having an actual teacher that you can sit with and a classroom full of others you can work with.
1. One of the questions is:
Determine a general equation for the quartic function f(x) as described:
f(x)<0 when x< -2, f(x)>0 when -2<x<3, and f(x)<0 when x>3, the zeros are -2, -1, and 3.
I've never worked with quartic functions or anything like this.
If anyone has some guidance that would be fantastic!
It's not much more than just an extension from quadratics/cubics.
The general form is y=ax^4+bx^3+cx^2+dx+e but this won't help much in this case.
Using the fact that for a quartic in the form y=a(x-b)(x-c)(x-d)(x-e), the roots are b, c, d, e so since you know the roots are -2,-1 and 3, It can be written as y=(ax+b)(x+2)(x+1)(x-3)
Now just see if you can add anything from the other info given. Such as finding whether a is positive or negative (the coefficient of the highest power (x^4) is important such as how it makes quadratics concave up or concave down).
Because "f(x)>0 when -2<x<3", the graph of f does not cross the x-axis at x= -1. But x= -1 is a zero so the graph must be tangent to the axis there. That means x= -1 is a double root" the four[/b roots are -2, -1, -1, 3, and so gives you the fourth factor that Mentallic writes as "ax+ b".
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
