Op Amp LM358 LED flasher oscillator
2 replies · 4K views · last reply
Amyniuo
Left: breadboard with an LM358 op amp, resistors, a 1uF capacitor and a red LED wired up. Right: hand-drawn schematic of the LM358 oscillator with 100k, 100k, 100k, 100k and 1k resistors, 1uF capacitor, 4V supply, and LED to ground.
I have tried many times testing some Op Amp LED flashing circuits on a breadboard from the internet. So far, none of them works. The photo above is one of my attempt using a
Ti IC chip LM358. I have double checked my wiring and swap the 100k with 10k and 56k resistors. what is the problem here? why it's so hard to get a led flasher working with an Op Amp? Also I notice some of the circuit diagrams in the internet don't have the left 100k resistor between v+ and non-inverting input. why is that?
Here is my copy of your pic.
Photo of a breadboard LM358 op amp circuit beside a hand-drawn schematic with 4V supply, 1uF capacitor, 1k resistor, LED and five 100k resistors, annotated with red question marks.
So where's the fifth resistor and check the connections to the +ve input.
I think omitting the non-inv input via R to +ve supply may be needed because not using split power and centre ground. If you omit it here, when op goes low the inv input can never get lower than non-inv.
