How Does Gravity Affect the Frequency Needed to Keep Water in a Jar on Mars?
  • Thread starter Thread starter Arman777
The discussion focuses on how gravity affects the frequency required to keep water in a jar moving in a vertical circle on Mars. The gravitational acceleration on Mars is significantly lower than on Earth, which alters the necessary frequency for the water to remain in the jar without falling out. The key equations used are centripetal force and gravitational force, leading to the conclusion that the frequency needed on Mars is approximately 0.27 Hz. Clarification is provided on the relationship between the forces, emphasizing that the centripetal force needed for circular motion must equal the gravitational force acting on the water at the top of the circle. Understanding this balance is crucial for solving the problem correctly.
Arman777
Insights Author
An open jar of water moves in a vertical circle of radius ##0.50m## with a frequency that is small enough to put the water on the verge of falling out of the jar at the top of to the circle.If the same demonstration were repeated on Mars,where the ##a_g## is only ##3.7 \frac {m} {s^2}## ,what is the change in the circling frequency to again put the water on the verge of falling out at the top point.
##a_r=\frac {v^2} {r}##
##v=2πfr##
##v=2πfr##
##m\frac {v^2} {r}=mg##
from these
I found ##0.27 Hz##, which its correct.But there's something that I confused.
##m\frac {v^2} {r}=mg## how can these can be equal..weight must point downward and the other force is pointing inward...? I didnt quite understand the logic..I tried to understand but I couldnt
Thanks
The equation does not equate two different forces. The left hand side tells you the magnitude of the centripetal force required if the water is to move in a circle of radius r. The right hand side represents what actually provides that force at the top of the circle. If the right hand side of the equation was larger than the left the water would move in a circle that had a radius less than r (eg it would fall out).
Ohh,I see now Thanks..
So in order for the water to fall out...
mg > mv^2/r
In order for it to just stay in the jar..
mg = mv^2/r
Likes Arman777
  • · Replies 19 ·
  • · Replies 19 ·
