Creating a Language for an Optical Computing System
The discussion revolves around the concept of developing a fully optical computer utilizing a cubic processor that employs light for processing signals. Key points include the need for a new programming language tailored to a base 8 system, as traditional binary systems may not effectively translate to optical mediums with multiple signal possibilities. The design of logic gates using optical components through refraction and reflection is emphasized, alongside concerns about the speed variations of different light colors affecting signal transmission. The goal is to create a mechanism that mimics human brain functionality using light as the signal carrier. The conversation also touches on the current state of optical computing, the challenges in creating optical transistors, and the necessity for further research and design development in this field.
Alexi-dono
lets say someone had an idea for a fully optical computer; that had a optical cubic processor, that refracted and reflected signals. into a optical "motherboard" (except it was not a flat board, more of a rectangle), how would one go about writing a language for such a thing (lets say a base 8 system RBYGOPWB)?
Computer science news on Phys.org
Why would the language be any different? It's either going to be sequential or parallel like today's cpu architectures. We have language features that handle both of these today.
To my understanding, all of those languages eventually break down into bits. My question is: how would you implement a bit system, into a medium that has more than 2 possibilities (yes I know about Q-bits, but that does not work with photons(at least I have not seen evidence of it)); if I was going to use a modern computing language.
So this is why I'm biased toward having new language.
This is what I have so far, for principals...
https://docs.google.com/drawings/d/1fmve0dVWO4at6Mjdp_ClUSZpmevtqq5RL9ljLGuEneE/edit?usp=sharing
For computing to occur, one need to design Logic Gates, eg AND, OR, XOR,... etc, from these optical components. Some digitization may be needed. What's your thought about that?
Another difficulty is, I doubt light color can be easily used as a signal carrier, since different color of light has different speed in a medium, and aberration/dispersion would be observed in the course of time.
Just my random 2 cents.
I hypothesize that all the logic gates could be made by; different combinations of refraction, and reflection. As for each band of light having different speeds, that is not necessarily a bad thing. My personal end goal with this; is to try to create a mechanism that functions like a human brain, except with light as the signal carrier. So I knew when I started this it would be both complicated, and impractical at times... Also each band of light is a different signal, this it why I said roygbpbw are base units...
We generally don't allow personal speculation and personal theory development on the PF. We prefer to discuss the state of the art and potential next steps. What have you read in the mainstream literature so far about "Optical Computing"? There's quite a bit of good information out there, based on real science...
I'm sorry...
Drakkith said:
Have you read this article yet? http://en.wikipedia.org/wiki/Optical_computing
Yes I have read it, and I looked into a lot of other sources. I think I have enough to begin designs now...
How do you plan to do the actual computing? Modern computers use transistors as the basic building block of almost all other components. What are you planning to use?
Are optical transistors not yet a thing? I know they're highly experimental, but the Wiki article makes me unsure if you can even call them real yet.
http://en.wikipedia.org/wiki/Optical_transistor
How I solved the transistor problem is a secret that I intend to keep, all I will say is that the pieces are there if you know what to look for... Can anyone suggest a good 3D modeling software; that can handle massive loads?
I seriously, seriously doubt that. Engineers and scientists have yet to create a commercially viable optical transistor, so the chances of someone in high school doing so are essentially zero. Thread locked.
Likes berkeman
  • · Replies 44 ·
  • Sticky
