What Is the Maximum Area of a Gothic Window With Given Constraints?
The maximum area of a gothic window, constrained by a total segment length of 6m and fitting within a 1m wide by 3m tall area, can be calculated using the perimeter equation 6 = 4x + 2y, where x represents the sides of the equilateral triangle and y represents the height of the rectangle. The area A is defined as A = 1/2 * x * h + x * y, with h being the height of the triangle. It is essential to recognize that the height h is related to x, and the maximum area may not utilize the full height of the 3m constraint due to the perimeter limitations.
  • Understanding of geometric shapes, specifically triangles and rectangles
  • Familiarity with calculus, particularly derivatives for optimization
  • Knowledge of perimeter and area formulas
  • Ability to solve equations involving multiple variables
  • Study optimization techniques in calculus to maximize area under constraints
  • Learn about geometric properties of equilateral triangles and their relationship to perimeter
  • Explore graphical methods for visualizing constraints in geometric problems
  • Investigate similar problems involving constrained optimization in geometry
Students studying geometry, mathematics educators, and anyone interested in solving optimization problems in constrained environments.
roman15
a gothic window it to be built with 6 segments that total 6m in length. The window must fit inside an area that is 1m wide and 3 meters tall. the triangle on top must be equilateral. What is the maximum area of the window.
so i made each of the sides of the trianle x and the width at the bottom of the rectangle x, then the sides of the rectangle equal to y. so the perimeter is 6=4x+2y
and the area A=1/2xh + xy
the height of the triangle would be 3-y wouldn't it? because then i plugged that in for h, and then isolated for y in the perimeter equation and plugged in y where it was necessary but i didnt get the right answer in the end after i got the derivative
No, you don't know h=3-y. Given your perimeter constraint the maximum area window might not touch all sides of the 1m by 3m area. All you really know is that x<=1 and y+h<=3. What is true that h is related to x just because x is the side of an equilateral triangle and h is the height.
I'm assuming your shape is like this?
Code:
[u]/\[/u]
|_|
Since the top has to be an equilateral triangle you know that 3 segments have to be equal (if the base of the triangle counts as a segment). Then you have 3 segments left over to play with (the sides below the triangle and the base of the window)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
