Optimizing Alpha Emitters for Efficient Transmutation: A Cost-Effective Approach
  • Thread starter Thread starter Strat-O
    Alpha
The discussion centers on the pursuit of transmuting elements using an alpha emitter, specifically seeking a reliable and cost-effective source with at least 5 Ci of radioactivity, a half-life over 60 days, and energy of at least 1.5 MeV. Americium-241 is identified as a potential candidate due to its availability in smoke detectors and favorable half-life of over 400 years, making it less frequently replenished. The cost of Americium is noted to be around $1,600 per gram, which could yield 3.5 Ci, suggesting a more manageable expense than initially anticipated. Participants emphasize the importance of adhering to regulatory guidelines before proceeding with any experiments involving radioactive materials. Overall, Americium-241 appears to be a promising option for the intended application.
Strat-O
I would like to pursue an idea that involves transmutation of elements using an alpha emitter. I figure that the production rate I would like to achieve would require about 5 Ci of radioactivity. What would be a good candidate, i.e. least expensive and reliable supply with a half life of > 60 days and an energy of at least 1.5 MeV? I've looked at Po-210 but according to wiki, the annual global production is about 100 grams per year and although I haven't worked it out the price per curie is probably prohibitively expensive.
Essentially looking for the biggest alpha-bang per buck!
Thanks
Thanks. After posting I thought about Americium because it's common in smoke detectors. It is a bit expensive at $160 per milligram but I think I can produce small amounts of product and scale it up.
1 gram of Americium would generate 3.5 Ci. I'm guessing that amount would cost far less than $160,000. The cool thing is with a 400+ year half life for Am-241, it would not need to be replenished often.
Strat-O
Price is outstanding. Looks like you can get a gram of Am-241 oxide for $1,600.
Strat-O
Read this - http://www.nrc.gov/reading-rm/doc-collections/cfr/part030/
I do believe there are a certain set of guidelines you should follow before you attempt this.
That makes sense.
