Optimizing Antenna Efficiency: Matching Frequency and Waveform
The discussion revolves around optimizing antenna efficiency by understanding the relationship between the generator's output frequency, waveform characteristics, and the dipole antenna's resonance. Participants explore concepts related to Fourier transformations, harmonic content of waveforms, and the implications for antenna matching.
  • Mica questions the relationship between the output voltage of a generator producing an impulse and the resulting frequency, suggesting that a 1 microsecond impulse corresponds to a fundamental frequency of 1 MHz.
  • Warren states that a square wave consists of odd integer harmonics, specifically mentioning the presence of third, fifth, and seventh harmonics.
  • Mica seeks clarification on how to determine these odd integer harmonics and inquires about the power calculation of these harmonics.
  • Warren provides a reference to a mathematical resource that explains the frequency and amplitude relationships of harmonics in a square wave.
  • Mica proposes that for efficient radiation from a dipole, it is necessary to match the generator's output frequency to the dipole's resonance frequency, questioning if a 1 GHz resonance would require a 1 nanosecond impulse duration regardless of waveform.
Participants have not reached a consensus on the implications of waveform characteristics for antenna efficiency, and multiple viewpoints regarding the relationship between frequency, waveform, and antenna matching remain present.
The discussion includes assumptions about waveform characteristics and their impact on antenna performance, but these assumptions have not been fully explored or resolved. The mathematical relationships presented may depend on specific definitions and contexts.
Mica
Hi,
I want to clarify some notiona in an antenna. The major components of an antenna are a generator, transmission line and an antenna (dipole). Let's say the whole system has a perfect matche, i.e. the dipole is about 70 ohms as the transmission line. If my generator ,the output voltage, is an impulse which has a duration in a micro second ( let's say 1 micro sec). So, the frequency of this generator is 1 Mhz? If the impluse is a square, the main fundamental frequency is 1 MHz and also , with others harmonics, I means if I do the Fourier Transformation am I right?
Thanks,
Mica
A square wave is composed of odd integer harmonics. The third, fifth, seventh, and higher order odd harmonics all have power in them.
- Warren
- Warren
How can I determined these odd integer harmonics ? and if is another wave form ? And the calculation of the power of these harmonics ?
Thanks,
Mica
http://mathworld.wolfram.com/FourierSeriesSquareWave.html
Look at equation 6.
The third harmonic has a frequency three times that of fundamental, and has an amplitude one-third that of the fundamental. The fifth harmonic has a frequency five times that of the fundamental and an amplitude one-fifth that of the fundamental.
- Warren
Thanks for the information. So, for my dipole radited efficiently, I just match the right frequency output of the generator ? I mean like if my dipole resonances at 1 GHz so, my impluse (voltage source) duration will be 1/1 GHz ( 1 nano second) independent of the wave form?
Mica
10K
