Can an Orange Break Through 1/2" Drywall?
  • Context: Undergrad
  • Thread starter Thread starter claegreid
The discussion centers on the feasibility of throwing an orange through a 1/2" sheet of drywall (gypsum board). Participants highlight that the strength of 1/2" drywall is relatively low, especially if the orange is frozen. The conversation suggests that a baseball pitcher or cricket bowler could achieve speeds exceeding 90 mph, which may be sufficient to penetrate the drywall. Additionally, references to the impact properties of drywall and the Effective Modulus of Rupture (MOR) per ASTM C 1396 are provided as essential factors in determining the outcome.
  • Understanding of basic physics principles related to force and momentum
  • Familiarity with drywall material properties and strength
  • Knowledge of ASTM C 1396 standards for gypsum board
  • Experience with projectile motion and impact analysis
  • Research the impact properties of drywall using resources like the Gypsum Association's guidelines
  • Learn about the Effective Modulus of Rupture (MOR) and its application in material science
  • Explore the physics of projectile motion to calculate the necessary force for penetration
  • Investigate methods for building a cannon to test the hypothesis safely
This discussion is beneficial for physics enthusiasts, material scientists, and anyone interested in experimental mechanics or the properties of construction materials.
claegreid
OK, PF, I have an argument to settle and I need some expert advice.
A friend of mine claims that it is possible to throw an orange through a 1/2" sheet of drywall (gypsum board); several other friends refute his claim. I would like to do the math to prove/disprove the theory, but my line of work doesn't give me a lot of practice with the physics of such dynamic elements.
Question to the forum: how would I go about setting up an equation solve for this problem.
Thanks in advance!
Why don't you just give it a try?
That's the next step. But if I find out how much force is necessary and it is more than a human arm can supply, then I will have to build a cannon of sorts to achieve what man cannot. :biggrin:
Thanks in advance!
1/2" drywall is not very strong. Especially if you freeze the orange first... :smile:
And don't forget that if a baseball pitcher or a cricket fast bowler did the experiment, the orange would hit the drywall traveling at more than 90 mph.
Perhaps google for the impact properties of drywall. If you can't find them you will have to do the experiment.
Don't try this at home, folks!
Uh, this seems to be outside the conditions of the OP... ? I refer to the word "throw"...
The question becomes one of whether the orange will fly apart from the acceleration or air turbulence before it gets enough momentum to break the drywall.
http://www.gypsum.org/wp/wp-content/uploads/2011/11/GA-235-10.pdf talks about drywall strength.
I'd have to learn more about the methods used for measurement of Effective Modulus of Rupture (MOR) per ASTM C 1396 to understand how to apply the numbers.
Are you considering a freestanding 4x8 sheet? or one nailed to 17" studs?
Only somewhat related, but I love this movie of a cannon firing a 2x4 through a brick wall.
  • · Replies 25 ·
  • · Replies 66 ·
  • · Replies 31 ·
  • · Replies 0 ·
  • · Replies 18 ·
