Orbit: impulse making orbit spherical
The problem involves a satellite in a highly elliptical orbit experiencing an impulse at its perigee, with the goal of analyzing the effects on the semi-major axis and semi-latus rectum through energy and angular momentum considerations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss taking differentials of the semi-major axis and semi-latus rectum, with some expressing confusion about the relationship between eccentricity and perigee distance. There are attempts to derive relationships between changes in these parameters and questions about the implications of the impulse on the orbit's characteristics.
The discussion is ongoing, with participants sharing their attempts to derive relationships and expressing uncertainty about the assumptions made regarding the perigee distance. Some have proposed potential equations relating the changes in parameters, while others seek clarification on the implications of their findings.
There is a noted confusion regarding the constancy of the perigee distance despite changes in the semi-major axis and eccentricity, as well as the implications of the impulse applied to the satellite.
Halleluwah
A satellite moving in a highly elliptical orbit is given a retarded force concentrated at its perigee. This is modeled as an impulse [itex]I[/itex]. By considering changes in energy and angular momentum, find the changes in [itex]a[/itex] (semi major axis) and [itex]l[/itex] (semi latus rectum). Show that [itex]\delta l = \delta a (1-e)^2[/itex], and hence that the effect is to decrease the period and apogee distance, while leaving the perigee distance unaffected. Show that the velocity at apogee increases, while that at perigee decreases.
[tex] a= \frac{l}{1-e^2} = \frac{GMm}{2|E|}[/tex]
[tex] l = \frac{J^2}{GMm^2}[/tex]
where [itex]J[/itex] is the angular momentum.
So I've tried to take differentials of [itex]a[/itex] and [itex]l[/itex] but haven't really got far. I have that [itex]\delta J = -Ib[/itex] where [itex]b[/itex] is the perigee and [itex]\delta |E| = vI[/itex] where [itex]v[/itex] is the velocity. I'm also a bit confused as to how the perigee remains constant according to the answers. The eccentricity should be changing, so what is [itex]e[/itex] in the answer - the previous one? The perigee is [itex]b =a(1-e)[/itex] so if [itex]a[/itex] changes then [itex]e[/itex] should compensate (and [itex]e[/itex] does depend on the angular momentum and energy). Any hints would be appreciated.
Looking at this again, we should have
[tex] \delta a = \frac{b}{(1-e)^2} \delta e[/tex]
so that [itex]b \delta e = \delta l[/itex] but I'm not sure how to show this.
So I've I think I found the relation which I will post. We have [itex]a (1-e^2) = l[/itex] so [itex]\delta a (1-e^2) -2ea \delta e = \delta l[/itex]. Also since [itex]b = a(1-e)[/itex], we have [itex]0 = \delta a (1-e) -a \delta e[/itex] or [itex]a \delta e = \delta a (1-e)[/itex]. Writing the first relation as [itex]\delta a (1+e)(1-e) - 2a e \delta a[/itex] and replacing the first term with the second relation we have [itex](1+e)a \delta e - a 2 e \delta e = \delta l[/itex] or [itex]a \delta e(1-e) = b \delta e = \delta l[/itex].
So my solution is cheating really, as it assumes that the perigee does not change. The answer given is that [tex]\delta a = -2(I/m) \sqrt{(1+e)a^3/GM(1-e)}[/tex]
Any hints?
  • · Replies 30 ·
