Orbital mechanics- change of inclination
The discussion revolves around calculating the delta-v required for changing a satellite's orbital inclination from Earth's plane to Mars' plane, specifically during a Hohmann transfer orbit. Participants are exploring the conditions under which this change should occur for minimal velocity change.
  • The original poster attempts to determine the mean motion and the appropriate bodies to consider for mass in their calculations. They express uncertainty about calculating the argument of perigee and question the optimal point for the inclination change. Other participants suggest identifying the intersection point of the orbits as a potential location for the change.
Participants are actively engaging with the problem, with some providing insights on where to apply the velocity change. There is a mix of interpretations regarding the optimal point for the inclination change, and while some guidance has been offered, no consensus has been reached.
There is a mention of an attached figure that may provide visual context for the discussion. The original poster is also navigating through the complexities of orbital mechanics, including the definitions and calculations involved.
subsonicyouth
I'm trying to solve this problem: What's the delta-v required to change a satellite's inclination from Earth's to Mars' plane? Where should the plane change be done for the minimum velocity change? ( Satellite's transfer will be done with Hohmann transfer orbit.)
I've found an equation on wikipedia (http://en.wikipedia.org/wiki/Orbital_inclination_change)
: dVi= [2sin(di/2)*(thesquarerootof(1-e^2))*cos(W+f)*n*a]/ (1+ecos(f))
where e is the eccentiricity,
W is the argument of perigee,
f is the true anomaly and n is the mean motion.
You have to find the mean motion which is the square root of (G*(M+m))/a^3 where M and m are masses of the bodies to solve the eq. What I don't understand, which 2 bodies am I going to use? The masses of Earth and Mars, or Sun and Mars? And, how can I calculate the argument of perigee? Also, I'm not sure but I thought that for the minimum delta-v change the plane change should be done on the apogee. Is it correct?
Thank you.
Take a look at the attached figure. can you spot where it would be "easiest" to make the orbit inclination change with minimal delta-V?
I think it should be at the intersection point where mars' and Earth's inclination are equal.
You mean where the latus rectum of the spacecraft 's orbit meets the spacecraft 's trajectory?
Yes, am I wrong?
subsonicyouth said:
Yes, am I wrong?
No, you are right.
:) All right, thanks for your help.
Glad to help.
in order to change orbital plane impulse velocity should be applied at the nodes
  • · Replies 86 ·
9K
  • · Replies 62 ·
