Orbital period around Schwarzschild radius
Kyrios
An observer is orbiting at a radius r = 3GM, \theta = \frac{\pi}{2} and \phi = \omega t where w is constant.
The observer sends a photon around the circular orbit in the positive \phi direction. What is the proper time \Delta \tau for the photon to complete one orbit and return to the observer?
Schwarzschild line element where dr =0 and d\theta =0.
From the line element we have
\left(\frac{d\tau}{dt}\right)^2 = 1 - \frac{2GM}{r} - r^2 \left(\frac{d\phi}{dt}\right)^2
\left(\frac{d\tau}{dt}\right)^2 = 1 - \frac{2GM}{r} - r^2 \omega^2
I was trying to use \omega^2 = \frac{GM}{r^3} but that just gives
\left(\frac{d\tau}{dt}\right)^2 = 1 - \frac{2GM}{r} - r^2 \frac{GM}{r^3}
\left(\frac{d\tau}{dt}\right)^2 = 1 - \frac{2GM}{r} - \frac{GM}{r}
\left(\frac{d\tau}{dt}\right)^2 = 1 - \frac{3GM}{3GM}
as r = 3GM. This gives zero and I'm not really sure what to do with it. Have I gone wrong somewhere? What should I do with the w?
Light follows light-like (naturally) geodesics. These have the defining property of ds=0 so it shoukd come as no surprise that it has length zero.
This makes me suspect that the problem wants you to compute the proper time for an observer at fixed spatial coordinates before the light signal comes back from the opposite direction.
I have already worked out the proper time for a stationary observer, \Delta \tau = 6 \pi GM. The question specifically states that the observer is not at fixed coordinates, but moving with \phi = \omega t and emitting a photon while orbiting.
I see, so note that the observer according to the problem statement is not necessarily moving on a geodesic. When you put ##\omega=0## you should regain your result for the stationary observer.
How can I simply assume that \omega = 0? It says that w is a constant. Since the previous question was for the case of the stationary observer, I'm quite sure that this one isn't after the same answer. Although I cannot see any way around it
You cannot. What I said was that, when you have solved your problem, letting ##\omega = 0## should give you the result you had before. Your answer to the current problem should depend on ##\omega##, which you can treat as an arbitrary constant (but with ##\omega^2 < 3GM/r^3## or you will have an observer following a non-time-like curve - as you found out for the limiting case already).
Edit: It is not necessary to solve the problem, but note that, regardless of the value of ##\omega##, the observer will have a non-zero proper acceleration.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
