Orbital vs. Angular Speed: What's the Difference in Circular Motion?
Orbital speed and angular speed are distinct concepts in circular motion. Orbital speed refers to the linear speed of an object moving along its circular path, measured in units like meters per second (m/s), while angular speed measures the angle covered per unit time, expressed in radians per second (rad/s). The relationship between the two is defined by the radius of the orbit, where orbital speed equals the radius multiplied by angular speed. It is important to ensure that both terms are used in the same context to avoid confusion. Understanding these differences is crucial for accurately discussing motion in physics.
alybtd
Is there a difference between orbital speed and angular speed when an object or star is considered to be in a circular motion around another?
Welcome, might want to post your Q in the proper area.. Welcome anyway..:redface:
Thanks!
Where should I ask that?
Depends if its a homework question or a general question. Respectively, homework or astronomy sections would work.
I would do a search here. I am sure this question has been asked about 3 million times! :smile:
Electron Spin
Welcome to PF!
alybtd said:
Thanks!
I've moved the thread to the General Physics forum.
Likes Electron Spin
Electron Spin
Thank you! I kinda found a way to figure it out and I found the right answer to what I was looking for, so yeah thanks!
Drakkith said:
Welcome to PF!
Thank you!
Likes Electron Spin
- Orbital speed means the speed transverse to the orbit. It is speed in the normal usage: distance traveled per unit time. It has units like m/s. For a circular orbit it is the circumference over the orbital period.
- angular speed differs in that it is the angle traveled per unit time. It has units like rad/s. For a circular orbit it is 2 π / the orbital period. Note: Since it is "transverse to the orbit" the direction at any point in time is well defined and this is often called orbital velocity.
The two are related by the radius of the orbit. For a circular orbit of radius r
Orbital speed = r * angular speed.
Caveat: if you are hearing both these phrases be careful that the speaker is using them both in reference to the same rotational motion. They might be using one in reference to the orbit and the other in reference to the spin or something like that.
  • · Replies 21 ·
19K
  • · Replies 23 ·
  • · Replies 19 ·
