Organic Chemistry Williamson Synthesis of an Ether
The discussion centers on the Williamson Ether Synthesis, specifically using para-chlorobenzyl chloride (C7H6Cl2) with sodium (Na) and 1-propanol to produce a benzyl ether (C10H13OCl). Participants explore alternative reactions to achieve the same product without altering the alkoxide or halide leaving group. Suggestions include considering different starting materials like benzyl chloride and cinnamyl chloride while maintaining the para position of chlorine. The conversation emphasizes the need for understanding the flexibility within the Williamson Ether Synthesis framework.
  • Understanding of Williamson Ether Synthesis
  • Familiarity with SN2 reaction mechanisms
  • Knowledge of IUPAC naming conventions for organic compounds
  • Basic concepts of organic reaction pathways and substituent effects
  • Research alternative starting materials for Williamson Ether Synthesis
  • Learn about the physical properties of reactants affecting yield
  • Explore IUPAC naming conventions for complex organic compounds
  • Investigate resources for pricing and availability of organic reagents
Organic chemistry students, educators, and researchers interested in ether synthesis and reaction mechanisms.
imdapolak
" Write an alternate reaction that can be used to prepare the same product that we got in our lab ( changing the metal in the alkoxide or halide leaving group is not sufficient.) Explain the reaction you used, is it expected to be cheaper cost wise, and or produce a higher yield, based on the physical properties of the reactants."
For the lab starting material we used para-chlorobenzyl chloride formula (C7H6Cl2) reacted with Sodium ( Na) + 1-propanol to get a chemical formula of C10H13OCL, which I am struggling to name but the prof suggested to just call it a Benzyl ether. My guess at the IUPAC name is para-chloro-benzyl-propoxy. The benzene ring has a cl at the para position, and at the meta there is a ch2-O-Ch2-Ch2-Ch3. I wrote out the Sn2 reaction for this problem but I am not sure how to write an alternate reaction to get the same product without using the same initial starting materials. I have been looking up other starting material compounds like benzyl chloride and cinnamyl chloride but I am not sure how to get chlorine in the para position, is there another reaction step I have to add to this? Any clarification on how to approach this problem would be greatly appreciated as my prof simply said "figure it out." Also, if anyone knows of a website that gives me the cost per mol of these starting materials that would be great, I am not sure how to look this up exactly.
Thanks in advance for any help
This should be in HW help section but I'll give a hint.
Also you are overthinking the question. I doubt you're professor wants you to start completely from scratch (like benzene and propane). She just doesn't want you to change the Chloride to a Bromide or the Sodium to a Potassium (which is very trivial and doesn't serve to teach you anything about the Williamson Ether Synthesis).
Hopefully you've gone through this in lecture, or have heard of this concept before. If you haven't, now is a good time to read the page or two in your text about it. Its actually a lot simpler than it seems at first glance.
What is the 'jist' of the Williamson Ether synthesis?
Where in this 'jist' is the area of flexibility?
  • · Replies 28 ·
  • · Replies 18 ·
11K
