Oscillation in quadratic potential
10 replies · 5K views
Idoubt
Can someone tell me how to approach this problem?
Find the period of oscillation of a particle of mass m, constrained to move along the x-axis, with a potential V(x)= a+bx+cx2 for a small disturbance from the equilibrium position.
tiny-tim said:
Hi Idoubt! :smile:
What equations do you know relating the potential to the motion? :wink:
well only thing I can think of here is that F=-2cx-b
and also that T+U=E ( T= K.E, U=P.E, E=total energy) but this isn't in the simple harmonic oscillator form F=-kx so I don't know how to proceed from here.
tiny-tim said:
How about a differential equation? :smile:
Well I thought about expressing the force equation in the terms of a phase angle like
x=x0cosa where x0 is the amplitude, and integrating and solving for a = 2pi , but uh I got a soup that I couldn't integrate :redface:
I solved the basic force equation md2x/dt2=-2cx-b and got the solution
x=Acos((2c/m)1/2t)+Bsin((2c/m)1/2t)+2c/b
In this it seems to me that (2c/m)1/2 is w the angular velocity
and if so since w=2pi/T the time period should pop out as
T=2pi(m/2c)1/2 , does that seem right?
yup … that's exactly right! :biggrin:
(btw, you could rewrite md2x/dt2=-2cx-b as d2(x+b/2c)/dt2=-(2c/m)(x+b/2c),
and in that form you can just read off T without having to find the general solution! :wink:)
V(x)= a+bx+cx2 is a parabola with a minimum (assuming that c>0) at x=-b/(2c). x=-b/(2c) is the equilibrium position.
Factror F=-2cx-b to get:
[tex]\displaystyle F=-2c\left(x-\left(-{{b}\over{2c}}\right)\right)[/tex]
This is in simple harmonic oscillator form. 2c is analogous to the spring constant, k.
You have, F = -k*u, where u=x+(b/(2c)) and k=2c.
Thank you both, that makes it a lot clearer. Here the term x+b/2c is the actual displacement from the equilibrium position right? so the formula F=-kx is applicable only what x=0 is the equilibrium position.
I don't know if it will help you or confuse you more, but Lagrangian formalism is very useful for dealing with problems of motion in given potential. Take a look at Wikipedia article. If it looks too scary, never mind.
