Oscillation Problem: Find Period and Potential Energy
The discussion focuses on determining the short oscillation period and potential energy of a mass "m" subjected to an external force described by Fx=-4*sin(3*pi*x). The user approximates the force for small oscillations, leading to the conclusion that the angular frequency ω is 12*pi/m, resulting in a period T of 2*pi*√(m/(12*pi)). The potential energy is derived as Ep=6*pi*x^2, assuming a spring-like behavior. However, there is a suggestion that the potential energy should correspond to the original force rather than the approximation, leading to a revised expression for potential energy as Ep=2*sin(3*pi*x)*x. The conversation also touches on the relationship between force, potential energy, and kinetic energy.
Misheel
mass "m" object is located near the origin of the coordinate system. External force was exerted on the object depending on the coordinate by the formula of Fx=-4*sin(3*pi*x). Find the short oscillation period, and the potential energy depending on the coordinate.
F=ma
I am not really sure what is the short oscillation period... but
since there is only 1 force:
F=Fx=ma
-4sin(3*pi*x)=m*(d^2*x)/dt^2
and assuming that the object will move very little (because it's said to be SHORT osccilation period ?)
sin(3*pi*x) is approximately 3*pi*x .
and since
2*x=(d^2*x)/dt^2 is the formula of the harmonic oscillation :
we find ω=12*pi/m
and the T=2*pi*√(m/(12*pi)) ?
and also assuming that in SHORT oscillation :
it is almost like a spring :
F=-12*pi*x=-kx
k=12*pi
potential energy is Ep= k*x^2/2=6*pi*x^2 ?
F=ma
F=Fx=ma
and since
we find ω=12*pi/m
This is fine.
F=-12*pi*x=-kx
k=12*pi
I think the problem is looking for the potential corresponding to the original force, not the approximation.
Thank You for your reply, Vela
umm...then, i have no other ideas other than using FORCE to solve this problem :PP which is :
F=-kx
Fx=F=-4*sin(3*pi*x)=-kx from this
we find k=4*sin(3*pi*x)/x
so Ep=kx^2/2=2*sin(3*pi*x)*x ?
is it right ? :P
Thanks
How are potential energy and force related in general?
Maybe the work done by force is divided into object's konetik and potential energy ?
  • · Replies 18 ·
