Oscillator Equation - Energy Conservation
The discussion centers on demonstrating the conservation of energy in the oscillator equation d²s/dt² + ω²s = 0. By assuming a solution of the form s(t) = Acos(ωt), it is shown that the energy E = 1/2(ds/dt)² + 1/2ω²s² remains constant. A more direct method involves taking the time derivative of the energy expression, resulting in dE/dt = s' s'' + s'(ω²s), which simplifies to zero using the oscillator equation. This confirms that energy is conserved, as dE/dt = 0. The conversation concludes with a clarification on a minor typo in the equations presented.
Paddyod1509
Given the Oscillator equation:
\frac{d2s}{dt2} + \omega2s = 0
Show that the energy:
E=1/2(\frac{ds}{dt})2 + 1/2\omega2s2
is conserved.
Any help at all appreciated! Thankyou
I think i have it. By assuming a solution of the form
s(t)=Acos(wt)
and showing that the energy = 1/2(A^2)(w^2) is constant, this proves conservation
There is a more direct approach: just take the derivative w.r.t. time of the energy exression and then use the differential equation to replace the second derivative. If the derivative of energy is zero then the energy is conserved...
hi cosmic dust, thanks for your reply!
so by taking the derivative wrt time of the energy expression, i get
dE/dt = s' s'' + s'(ω^2s^2)
which is just s' times the given oscillator equation, which is zero, so:
dE/dt = s'(0)=0
So basically, by showing dE/dt = 0, i have shown that energy is conserved?
Precisely.
One of your lines has a typo, though. It's s'(ω²s) not s².
Thankyou sir, much appreciated
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
