Calculating the Osculating Circle for a Parametric Curve: A Scientific Approach
  • Thread starter Thread starter kasse
    Circle
The discussion focuses on calculating the osculating circle for the parametric curve defined by x(t)=cos(t), y(t)=sin(t), and z(t)=t at t=pi. The user has successfully determined the position, velocity, unit tangent vector, acceleration vector, and curvature at this point. They seek guidance on finding the unit normal vector without using the tangent and normal components of acceleration, noting that the normal is derived from the derivative of the unit tangent vector. An alternative method proposed involves using three points on the curve to calculate the osculating circle as delta approaches zero. The conversation emphasizes the simplicity of the calculations in this specific case.
kasse
I don't know if I've used the correct english terms in this text. Anyway, I'm working with the curve
x(t)=cos(t)
y(t)=sin(t)
z(t)=t
I have found the position and velocity vectors and scalars at t=pi. I've also calculated the unit tangent vector by dividing the velocity vector by the instant speed.
Next, I found the acceleration vector at t=pi and the curvature, and I'm now about to find the unit normal vector at t=pi. How can I do that without calculating the tangent and normal component of the acceleration first? (I'm not allowed to to it that way, and I'm going to use the information to find the osculating circle).
The normal to the curve is the derivative of the unit tangent vector. To get the unit normal curve, of course, divide by its length. It happens to be particularly simple in this case!
Who says you 'aren't allowed'? The only other way I can think of to calculate an osculating circle is to take three points on the curve, say at t=pi, pi+delta, pi-delta, calculate the circle thru them and then let delta->0.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
