Osmotic pressure=hydrostatic pressure in Ushaped tube
  • Context: Undergrad
  • Thread starter Thread starter gracy
    Pressure Tube
Osmotic pressure is defined as the pressure required to halt the flow of solvent molecules due to osmosis. In a U-shaped tube, hydrostatic pressure equates to osmotic pressure, effectively balancing the two forces. This principle is not exclusive to U-shaped tubes; it applies universally in systems where solvent movement occurs, such as sealed porous bags containing solute in pure solvent. The chemical potential difference drives solvent movement until equilibrium is reached.
  • Understanding of osmosis and osmotic pressure
  • Knowledge of hydrostatic pressure principles
  • Familiarity with semipermeable membranes
  • Basic concepts of chemical potential
  • Research the principles of osmosis in different setups
  • Explore the role of semipermeable membranes in biological systems
  • Study the effects of osmotic pressure on cell behavior in various environments
  • Investigate applications of osmotic pressure in industrial processes
Students and professionals in biology, chemistry, and environmental science, particularly those studying fluid dynamics, cellular processes, and osmotic phenomena.
gracy
osmotic pressure is the pressure required to stop the flow of solvent molecules due to osmosis.So in case of U shaped tube as in the image below hydrostatic pressure is the pressure which will stop the flow of solvent molecules due to osmosis. So hydrostatic pressure =osmotic pressure right?And if yes is it only in case of u-shaped tube?
http://biology-forums.com/index.php?action=dlattach;topic=196955.0;attach=45336;image
Yes, the hydrostatic pressure balances the osmpotic pressure. This will occur in any set-up. Doesn't need to be u-shaped.
You can also see the same thing with a sealed, porous (to solvent) bag with some solute placed in a pure solvent. The solvent will go from bath to bag (the chemical potential of the solvent in the bag is lower than the pure solvent), and molecules "want" to move from regions of high chemical potential to low. The bag will fill, and the pressure in the bag will increase until the pressure in the bag equals the osmotic pressure.
A cell is just a semipermeable bag of solute. You can get cells to swell up and sometimes rupture by putting them into pure water.
  • · Replies 31 ·
11K
  • · Replies 40 ·
  • · Replies 19 ·
  • · Replies 49 ·
