Can Oxygen Labeling Prove the Esterification Reaction Mechanism in P&D Lab?
  • Thread starter Thread starter rock.freak667
    Lab
The discussion revolves around testing the esterification reaction mechanism between ethanol and ethanoic acid, specifically focusing on the role of the -OH group from the acid. A proposed hypothesis involves labeling the oxygen in either reactant with O-18 to trace its incorporation into the ester product. The suggested experimental design includes reacting the labeled compounds, extracting the ester, and analyzing it using mass spectrometry. Concerns arise regarding the separation of the ester from water, with suggestions of using pipetting or steam distillation, though the latter is cautioned against in acidic or basic conditions. Ultimately, the discussion emphasizes the importance of proper extraction techniques for accurate analysis.
rock.freak667
Homework Helper
Some students had a disagreement about the esterification reaction between ethanol and ethanoic acid. Student A feels that the -OH group from the acid combines with the H from the alcohol functional group.
Suggest a hypothesis for his feeling and design a lab to test the hypothesis.
C_2H_5OH + CH_3COOH \rightarrow CH_3COOC_2H_5 + H_2O
Ok, well my idea would be to somehow label the oxygen on either the acid or the alcohol. I chose O-18. But I am not sure what steps are taken to actually label the oxygen like that.
Then react the two, extract the ester formed, and run it through a mass spectrometer. But when the ester is formed, it is formed in a layer with water,how do I separate the two? (Simple pipette and extract until it looks like all has been pipetted?)
You can buy O-18 labelled water. Any help?
If you injected it into a GC-MS you wouldn't have to separate anything...
Ah well all I need to say is that I labelled the oxygen. So no need to elaborate on it.
But apparently I must use the normal mass spec. I know so I would need to extract it somehow. I'm thinking steam distillation.
Not a good idea in the presence of either an acid or base. Maybe diluting in solvent and drying with Na2SO4 after washing with bicarb.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
