What is the purpose of the depletion region in P-N junction semiconductors?
The depletion region in P-N junction semiconductors, specifically in PN junction diodes, plays a crucial role in current flow. When forward biased, the width of the depletion region decreases, allowing diffusion current to increase as electrons from the N region move to the P region. This process does not widen the depletion region; instead, it maintains the barrier independent of the applied voltage until the drift current begins to flow. Understanding the distinction between drift and diffusion currents is essential for grasping the behavior of semiconductor devices.
  • Basic understanding of semiconductor physics
  • Knowledge of P-N junction diode operation
  • Familiarity with concepts of drift and diffusion currents
  • Understanding of forward and reverse biasing in diodes
  • Study the principles of semiconductor physics in detail
  • Learn about the characteristics and applications of PN junction diodes
  • Explore the concept of electric fields in semiconductor devices
  • Investigate the role of depletion regions in various types of diodes
Students and professionals in electrical engineering, semiconductor researchers, and anyone interested in understanding the operational principles of PN junction diodes and their applications in electronic circuits.
Praveen1901
I'm new to semiconductors.
While I was studying types of biasing in semiconductors, here's what I read -
'In forward biasing, the width of the depletion region is reduced.'
Here's what I thought -
Since the potential barrier is reduced in the junction due to external potential, the diffusion Current directed from p to n side should increases, leaving behind more -ve charge on P side and more +ve charge on the n side, and thus increasing the depletion region.
Please correct me where I'm wrong :)
First, by saying semiconductor, I think you really mean PN junction diode.
Now, drift current is the tiny amount of current that flows when hole/electrons move from where they are highly concentrated to a region of lower concentration. This doesn't say anything about due to application of electric field. Any current that flows due to electric field is drift current. Now you may say that this drift current may however still cause the depletion layer to widen. No, it won't.
You can consider it this way, if I have such a PN Junction diode and I forward biase it, the little electrons at the P region will get attracted to the positive terminal of the battery/power source. But immediately, this electrons will be replaced by other electrons from the N region since there are no more electrons in P to prevent such crossing over (remember the electrons at the P region was formerly preventing more electrons from crossing, which is what creates the layer in the first place).This is still a diffusion current. This crossing over would have kept the barrier independent of voltage applied (imagine manually, like by hand, removing the electrons at the P region, the diffusion will still happen) but as you said the applied electric field opposes the barrier field until it goes to zero then drift current flows.
You can also consider it that the barrier creates a large resistance (almost open circuit) at that drift current can't flow. Only diffusion can.
29K
10K
