Parallel light rays through a sprial wave plate diverge?
Spinnor
Do parallel light rays diverge if ever so slightly upon exiting a spiral wave plate? See image below.
Diagram of a spiral phase plate: a stepped disk with sectors of increasing thickness, height s and angle alpha, with a red beam hbar k entering and exiting at angle theta, labelled p_phi and r.
Diagram of a spiral phase plate: on the left, a TEM00 beam of concentric bright rings enters; a helical beam with a spiral wavefront exits on the right; labels show angles phi, alpha, radius r and step height d.
Images from,
https://www.google.com/search?q=spiral+phase+plate&safe=off&sa=X&es_sm=122&biw=1360&bih=649&tbm=isch&tbo=u&source=univ&ei=xEGDVcaKFYLV-AHZop_IAw&ved=0CC0QsAQ#imgrc=V_wYVTQHs9_JcM%3A;MIMazroQRD_VYM;http%3A%2F%2Fupload.wikimedia.org%2Fwikipedia%2Fcommons%2F1%2F1f%2FSpiral-phase-plate.png;http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FAngular_momentum_of_light;1047;382
If there is divergence does that change the angular mementum of the light?
Thanks for any help!
If there is no interface between those glas parts where would you expect any special things but a straight beam?
It makes no sense from the very beginning.
The first image above seems to show a typical light ray bending.
Come on... the symmetry is circular and waves here are as I expect them...it seems to be homogenieous material ... you can find silly ways to bend light but in the end you will have nothing but light, may be polarized. From symmetry reasons the outcouming is nonsense. If it is homgeneous stuff.
May be harsh critics but I think Spinnor will report about it.
