Parallel Plate Capacitance and Charge Time
The discussion focuses on calculating the capacitance and charge time of a parallel plate capacitor using the formula \(C=K\varepsilon_0\frac{A}{d}\). The correct capacitance value is determined to be \(2.25307 \times 10^{-11} F\) or \(0.0000225307 \mu F\), not \(22.531 \mu F\) as initially stated. The time constant for the circuit is calculated as \(t = 0.019 \Omega \times 0.00002253 \mu F\), leading to a charging time of approximately \(5 \times t\) for practical applications. The discussion emphasizes the importance of dimensional consistency in calculations and the distinction between theoretical and engineering solutions regarding capacitor charging.
  • Understanding of capacitance calculations using \(C=K\varepsilon_0\frac{A}{d}\)
  • Familiarity with time constants in RC circuits
  • Knowledge of exponential functions and their applications in electrical engineering
  • Ability to interpret and correct dimensional inconsistencies in equations
  • Learn about the implications of time constants in RC circuits
  • Explore the differences between theoretical and engineering approaches to capacitor charging
  • Study the use of online calculators for capacitance and charge time verification
  • Investigate the effects of dielectric materials on capacitance values
Electrical engineers, physics students, and anyone involved in circuit design or analysis will benefit from this discussion, particularly those focusing on capacitor behavior and calculations.
HelloCthulhu
A 6V battery, 0.64mm diameter/14in length single/solid copper wire alligator clips how long and an 18cm disc parallel plate air capacitor are used in a circuit. What is the capacitance? How long will it take to charge the capacitor to 100% of its capacity?
A=πr2
capacitance
$$C=K\varepsilon_0\frac{A}{d}$$
Area of 18cm disc electrode = 0.0254469m2
d of separation = 0.01m
dielectric constant = 1
ε0 = 8.85×10−12 F/m−1
voltage respect to time
V(t) = VB(1-e[SUP]-t/RC[/SUP])
V(t) = voltage in respect to time
VB = battery voltage
-e (numerical constant) = 2.71828
-t = voltage in respect to time in sec
R = resistance of the wire
C = capacitance
RC = time constant = τ
resistance for the 14in long/ 0.64mm diameter wire found here:
https://www.cirris.com/learning-center/calculators/133-wire-resistance-calculator-table
$$C=K\varepsilon_0\frac{A}{d}=C=\frac{(8.85\times10^{-12})\times1\times 0.0254469}{0.01}=0.000022531F=22.531μF$$
6V*(1-2.71828-t/0.019Ω*0.0000225307uF)
time constants
6*(1-2.71828-1) = 6*(0.632) = 3.79 sec
6*(1-2.71828-2) = 6*(0.865) = 5.18 sec
6*(1-2.71828-3) = 6*(0.950) = 5.70 sec
6*(0.982) = 5.89 sec
6*(0.993) = 5.95 sec
capacitance = 22.531μF
100% charge time = 6 sec
0.993 is not equal to one. You also did not solve for t so your equations are dimensionally inconsistent.
I apologize this is my first time doing this kind of equation. I used this video to learn about time constants:
In this equation I still have the -t value over the RC value:
6V*(1-2.71828-t/0.019Ω*0.00002253)
After the RC value was solved, I should've written these equations as:
6V*(1-2.71828-4.280833e-7/4.280833e-7)
6V*(1-2.71828-1)
6V*(0.632) = 3.79 sec
Again, you are being dimensionally inconsistent. 6 V multiplied by a dimensionless number still has units of volts. What you have computed is the capacitor charge after a time t=RC. This is not what the question asked for, the question asked when the capacitor would be fully charged, ie, when (for what t) does the capacitor charge become 6 V?
Ok, I was definitely confused earlier. I found a more detailed tutorial on this, so I hope I have a better understanding of time constants and charging time now:
https://www.electronics-tutorials.ws/rc/rc_1.html
1t = 0.019Ω*0.00002253uF = 4.280833e-7 secs
5t = 5X4.280833e-7 = 0.00000214041 secs
You might want to check your exponent calculations for the capacitance calculation. I can't imagine how an 18 cm disc capacitor separated by 10 mm of air can give such a large capacitance (the numbers of the mantissa look good, but I think the power of 10 you've ascribed to the exponent is incorrect).
You're absolutely right. I submitted 22.531μF as the solution to the capacitance equation. But the capacitance is 2.25307x10-11F (0.0000225307μF).
$$C=K\varepsilon_0\frac{A}{d}=C=\frac{(8.85\times10^{-12})\times1\times0.0254469}{0.01}=2.25307\times10^{-11}F=0.0000225307μF$$
I used this online calculator to check the work. Hope I got it right this time.
https://www.omnicalculator.com/physics/capacitance
Yup. So think pF rather than ##\mu F## for the capacitance value.
Your idea of suggesting that a period of 5 time constants will settle the matter is good in "engineering" terms. It is true that the engineering rule of thumb is that everything of interest in a circuit has occurred after a period of five time constants. However, be aware that theoretically, a charging (or discharging) capacitor will never reach it's final charge in a finite amount of time. In other words, this may be a trick question. You may want to review the original question as presented to you to be sure that it is asking for an "engineering" solution or a theoretical one.
  • · Replies 26 ·
18K
  • · Replies 21 ·
