Parallel RL circuits for impedance matching and filtering
This query comes from not being able to answer some one else's query :oops:
it show's I have been away from textbooks and classrooms way too long ( see my signature )
I have forgotten my basics
These RL circuits
Three circuit diagrams labelled A, B and C: A and B show an AC source with a resistor R1 and inductor L1 in parallel, drawn in different orientations; C shows the same parallel RL network in series with a load resistor labelled Load.
Now I realize A and B are just the same with the RL rotated
and following that C would be the same as B with the load inserted below the RL
For C ... What difference is there if the load is say
1) antenna
2) some other circuit on a separate module ( possibly/probably capacitively coupled)
or if circuit B and the load was parallel across the source and the RL network ?
Bouncing around a number of www sites infers that the parallel RL is used as a form impedance matching
between the source and load ?
I cannot find specific comments for another use ... is there one ?
I was considering a filter ...
with ref to ...
http://amrita.vlab.co.in/?sub=1&brch=75&sim=322&cnt=1
Theory:
With an ac signal applied to it, the parallel RL circuit shown below offers significant impedance to the flow of current. This impedance will
Circuit schematic of an AC voltage source on the left feeding a resistor R and an inductor L connected in parallel across the source terminals.
change with frequency, since that helps determine XL, but for any given frequency, it will not change over time.
Then gets into a mass of complex impedance calc's as most sites do
one place seen was in an FM phase modulator circuit ...
Circuit schematic of a varactor diode phase modulator: crystal oscillator input, R1, capacitors, a varactor diode, R2, a parallel R1 and L1 load, modulating signal input, and phase modulated output. Labelled Figure 3.
I haven't played with phase modulation circuits ... so not too sure of the process therea little help in understanding please :smile:
cheers
Dave
Seems to me that "mass of calc's" was unnecessary.
Why they let it get more complex than this, their own starting point,
Equation for parallel impedances: 1/Z = 1/R + 1/(jX_L).
is a mystery to me.
You'll remember this from 1960s...
Every new scientist must learn early that it is never good taste to designate the sum of two quantities in the form:
Rendered equation reading 1 + 1 = 2 with the label (1) at the right, a deliberately flawed derivation in a joke image.
Anyone who has made a study of advanced mathematics is aware that:
Trigonometric identity 1 = sin^2 x + cos^2 x written as a single line of mathematics.
Handwritten-style equation: 2 = sum from n=0 to infinity of 1/(2^n), with the series written as a summation sign over the terms.
Therefore eq. (1) can be expressed more scientifically as:
Equation ln e + sin² x + cos² x = sum from n=0 to infinity of 1/2^n, labelled (2), with a sum over powers of one half.
This may be further simplified by use of the relations:
Equation 1 = cosh y sqrt(1 - tanh^2 y), with the square root covering 1 minus tanh squared y.
Limit definition of Euler's number: e = lim (z→∞) of (1 + 1/z)^z.
Equation (2) may therefore be rewritten as:
Typeset equation (3): ln lim_{z->∞} (1 + 1/z)^z + sin^2 x + cos^2 x = sum_{n=0}^∞ cosh y sqrt(1 - tanh^2 y) / 2^n
At this point it should be obvious that eq. (3) is much clearer and more easily understood than eq. (1). Other methods of a similar nature could be used to clarify eq. (1), but these are easily divined once the reader grasps the underlying principles.
https://totient.wordpress.com/2008/03/19/a-funny-derivation/
@jim hardy haha ... why do people do that to us poor non-mathematical people
and 1+1=2 also depends on who you are ... a statistician, mathematician, an engineer or a philosopher :wink:
But we digress
Any help with understanding what this RL circuit is doing ?Dave
Circuit C ?
I'd treat it as a voltage divider.
Vout = Vin X (Rload)/(Rload + (R1 parallel L1))
and plot Vout/Vin for frequencies where XL<< either resistor to XL>> either resistor.
At DC, Vout = Vin
and when XL>> either resistor, Vout = Vin X Rload/(R1+Rload)
If one sets Rload = K*R1
there's some frequency where XL = R1, ω = R1/L1, so one could derive a family of curves of attenuation vs frequency.for various K's
Sound plausible?
old jim
