CannonSLX
- 40
- 0
General wave solution y=f(x+ct)+g(x-ct) [/B]
Graphical sketch
How do I check my answer satisfies the boundary conditions please?haruspex said:Your solution to the first part is essentially right, but the logic flow is backwards. You have shown that if the differential equation has solutions of the given form then the parameter must be ±2. You were asked to show that with a parameter of either of those values a function of the proposed form is a solution to the equation.
For the second part, I'm not sure what is wanted, so cannot comment.
In the last part, did you check that your answer satisfies the boundary conditions?
Plug in t=0.CannonSLX said:How do I check my answer satisfies the boundary conditions please?
So is that substituting t=0 into the final solution I have at the bottom right to achieve what exactly, please?haruspex said:Plug in t=0.
To see whether it yields y(x,0)=sin(x).CannonSLX said:So is that substituting t=0 into the final solution I have at the bottom right to achieve what exactly, please?
when t=0haruspex said:To see whether it yields y(x,0)=sin(x).
Which gives 0, not the required sin(x). So find your error.CannonSLX said:
Dont see my error from my workingsharuspex said:Which gives 0, not the required sin(x). So find your error.
Look at the equation where you introduce the constant B. Check the sign of the sin(x) term.CannonSLX said:Dont see my error from my workings![]()
I see, it should be + sin(x)/2haruspex said:Look at the equation where you introduce the constant B. Check the sign of the sin(x) term.
Take a closer look at your post #7. There is some cancellation. As it is there, everything cancels, but with the corrected sign it will give the desired result.CannonSLX said:I see, it should be + sin(x)/2
But I don't see how substituting t=0 will provide the result of y(x,0)=sin(x), as its sin(x)/2 along with an exponential function.
