What Are the Conditions for Uniqueness in Solving This PDE?
In summary: U_{0}(x_{0}-y_{0})^{3}$, we get:$$U(x_{0},y_{0})=U_{0}(x_{0}-y_{0})^{3}=2\left(f''(x_{0})-g''(y_{0})\right)(x_{0}-y_{0})^{2}-12\left(f'(x_{0})+g'(y_{0})\right)(x_{0}-y_{0})+24\left(f(x_{0})-g(y_{0})\right)$$Simplifying this equation, we get:$$f(x_{0})-g(y_{0})=\frac{
abiyo
43
Consider the PDE
U_{xy}+\frac{2}{x+y}\left(U_{x}-U_{y}\right)=0
with the boundary conditions
U(x_{0},y)=k(x_{0}-y)^{3}\\
U(x,y_{0})=k(x-y_{0})^{3}
where $k$ is a constant given by $k=U_{0}(x_{0}-y_{0})^{3}$. $x_{0}$, $y_{0}$ and $U(x_{0},y_{0})=U_{0}$ are known. The solution for the PDE is given by
U(x,y)=(x-y)^{5}\frac{\partial ^{4}}{\partial x^{2}\partial y^{2}}\left(\frac{f(x)-g(y)}{x-y}\right)
After some simplifications I get
U(x,y)=2\left(f''(x)-g''(y)\right)(x-y)^{2}-12\left(f'(x)+g'(y)\right)(x-y)+24\left(f(x)-g(y)\right)
where $f(x)$ and $g(y)$ are to be determined. I am looking for conditions that ensure uniqueness for the solution of this PDE. Any help will be appreciated.
Thanks, Abiyo
p.s I tried the following approach but it didn't work.
U(x_{0},y_{0})=2\left(f''(x_{0})-g''(y_{0})\right)(x_{0}-y_{0})^{2}-12\left(f'(x_{0})+g'(y_{0})\right)(x_{0}-y_{0})+24\left(f(x_{0})-g(y_{0})\right)
$$ There are six unknowns $f(x_{0}),f'(x_{0}),f''(x_{0}),g(x_{0}),g'(x_{0})$ and $g''(y_{0})$. Assume $5$ values and the sixth one is determined. From there I proceed to find two ODEs and can find a solution to the PDE. The solution depends on my choice of these constants and hence I am looking for a constraint on this constants.
Dear Abiyo,
Thank you for your post. Your approach using the six unknowns and setting five values to determine the sixth one is a good start. However, you are correct in looking for a constraint on these constants to ensure uniqueness of the solution.
One way to ensure uniqueness is to use the boundary conditions given in the problem. We can substitute the boundary conditions into the solution for the PDE and equate it to the given boundary conditions. This will give us two equations in terms of $f(x)$ and $g(y)$, which we can solve to determine the values of these functions.
For the first boundary condition, we have:
U(x_{0},y)=k(x_{0}-y)^{3}=2\left(f''(x_{0})-g''(y)\right)(x_{0}-y)^{2}-12\left(f'(x_{0})+g'(y)\right)(x_{0}-y)+24\left(f(x_{0})-g(y)\right)
Setting $y=y_{0}$ and using the fact that $k=U_{0}(x_{0}-y_{0})^{3}$, we get:
f(x_{0})-g(y_{0})=\frac{U_{0}}{24}
Similarly, for the second boundary condition, we have:
U(x,y_{0})=k(x-y_{0})^{3}=2\left(f''(x)-g''(y_{0})\right)(x-y_{0})^{2}-12\left(f'(x)+g'(y_{0})\right)(x-y_{0})+24\left(f(x)-g(y_{0})\right)
Setting $x=x_{0}$ and using the fact that $k=
FAQ: What Are the Conditions for Uniqueness in Solving This PDE?
1. What are PDE conditions for uniqueness?
PDE conditions for uniqueness refer to the mathematical criteria that must be satisfied in order for a partial differential equation (PDE) to have a unique solution. These conditions ensure that there is only one possible solution to the PDE, rather than multiple solutions that could potentially lead to conflicting results.
2. What are the main PDE conditions for uniqueness?
The main PDE conditions for uniqueness include the Lipschitz condition, the maximum principle, and the Fredholm alternative. The Lipschitz condition states that the coefficients in the PDE must be bounded and continuously differentiable. The maximum principle ensures that the solution to the PDE cannot exceed the boundary conditions. The Fredholm alternative guarantees that a unique solution exists if certain compatibility conditions are met.
3. Why are PDE conditions for uniqueness important?
PDE conditions for uniqueness are important because they provide a way to verify the validity of a solution to a PDE. If these conditions are not satisfied, it is possible that the solution may be incorrect or that multiple solutions exist. By ensuring that the PDE has a unique solution, we can have more confidence in the accuracy of our results.
4. How do PDE conditions for uniqueness relate to physical systems?
PDE conditions for uniqueness are closely related to physical systems because they help us determine whether a mathematical model accurately represents a physical phenomenon. If the PDE conditions for uniqueness are satisfied, then the solution to the PDE can be interpreted as the unique behavior of the physical system. This allows us to make predictions and analyze the behavior of the system with more confidence.
5. Are PDE conditions for uniqueness always easy to satisfy?
No, PDE conditions for uniqueness can be quite difficult to satisfy in some cases. For example, the Lipschitz condition may be challenging to verify for complex systems with non-linear equations. Additionally, the Fredholm alternative may be difficult to apply in systems with non-homogeneous boundary conditions. However, these conditions are important to consider in order to ensure the accuracy and uniqueness of the solution to a PDE.
