Pendulum conservation of energy question
The discussion focuses on solving a pendulum conservation of energy problem involving a 300g ball attached to a 1.4m string, initially pulled to a 30-degree angle. The key calculations include determining the speed of the ball at a 20-degree angle, which is 1.42 m/s, and the maximum speed, calculated to be 1.92 m/s. Additionally, the angle at which the speed is one-third of the maximum value is found to be 29.5 degrees. The conservation of energy principles are applied throughout the problem-solving process.
  • Understanding of conservation of energy principles
  • Ability to apply trigonometric functions in physics problems
  • Familiarity with potential and kinetic energy equations
  • Basic knowledge of pendulum motion dynamics
  • Study the derivation of the conservation of energy formula in mechanical systems
  • Learn how to apply trigonometric functions to solve physics problems involving angles
  • Explore the effects of mass and height on potential energy in pendulum systems
  • Investigate the relationship between maximum speed and angle in pendulum motion
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for practical examples of pendulum dynamics.
neoaddict
To make a pendulum, a 300g ball is attached to one end of a string that has a length of 1.4m and negligible mass. (The other end of the string is fixed) The ball is pulled to one side until the string makes a 30 degree angle with the vertical, then (with the string taut) the ball is released from rest. Find a) the speed of the ball when the string makes a 20 degree angle with the vertical and b) the maximum speed of the ball. c) What is the angle between the string and the vertical when the speed of the ball is one-third is maximum value?
m=0.300kg
length=1.4m
angle=30 degrees with vertical
vinitial=0 m/s
ETinitial=mgh
ETfinal=0.5mv^2 + mgh
ETinitial = ETfinal
a) I tried using cos20=adj/hyp and isolated adj, and subtracted adj from 1.4 to figure out the distance from the floor to the bottom of the mass on the string. I then tried substituting that answer into the equation above and tried to isolate final velocity without much success. (The answer should be 1.42m/s)
b) I tried doing the same thing as a, except that ETfinal would not have mgh because it would be at its terminal velocity when h=0. The answer should be 1.92 m/s
c) I tried solving this by multiplying all the terms with speed by 1/3, but it requires knowledge gained from the above two questions to be solved. The answer should be 29.5 degrees
Thanks.
Here is how we start.
We will take the lowest point of the path of pendulum to 0 potential energy (our reference line). (we will call the fixed point O)
Draw the pendulum at 30 degrees. From the pendulum draw a horizontal line to meet a line from O to the lowest point (where the lines meet, we will call A). The distance from O to the lowest point is 1.4m and the distance from O to the pendulum is also 1.4m.
Can you find the length OA?
EDIT: since you are offline and won't probably be online when I am again I will continue the explanation.
When you get the distance OA, you can find the Total energy at the initial position with mgh.
Now re-draw the diagram with 20 degrees and similarly find the perpendicular distance from the line through the lowest point in the path of the pendulum. You can now get the potential energy at this distance (at this angle of 20 degrees).
So the potential energy at 20 degrees + kinetic energy at 20 degrees=Total energy of pendulum.
You should now be able to get out part a)
For part b) conservation of energy says that
Total Energy = potential energy + kinetic energy and the values of potential and kinetic increase/decrease along the the path of the pendulum, at which point will all the energy be entirely kinetic?
Part c) When you find vmax, use a little backwards logic with part a)
cos 30 = adj/hyp
cos 30 = adj/1.4
1.21m = adj
1.4 - 1.21 = 0.19m off the ground
cos 20 = adj/hyp
cos 20 = adj/1.4
1.32m = adj
1.4 - 1.32 = 0.08m off the ground
mgh = 0.5mv2 + mgh
gh = 0.5v2 + gh
9.8(0.19) - 9.8(0.08) = 0.5v2
1.47 m/s = v
Although it's close, it's about 0.05 m/s off from the answer. D:
Complete Solution Removed
Hootenanny
What is lcos?
Your method is correct. Two points, first off you assume the pendulum is hung 1.4meters above the ground, which we don't know. It does not matter either, because the only thing that matters is the difference in potential energy. If you don't see it just replace 1.4 with h. You will see it drops out.
Point 2. You are making a lot of small steps and every time you calculate you make a rounding error, this is why your answer is not correct. I would suggest you to not round up or down until the very end.
  • · Replies 31 ·
  • · Replies 29 ·
  • · Replies 20 ·
