Pendulum in polar coordinate system problem
The discussion focuses on solving the dynamics of a pendulum in a polar coordinate system, specifically addressing the displacement of the particle and the tension force T in the thread. Key equations include Newton's Second Law (NII: ∑F=ma) and the period formula T=2π√(l/g). The participant, Mikael, initially struggled with the conversion to polar coordinates but received clarification on using the unit vectors er and eθ, which are essential for analyzing motion in this system. The correct approach involves decomposing gravitational forces into radial and tangential components to derive the motion equations.
  • Understanding of Newton's Second Law (NII: ∑F=ma)
  • Familiarity with polar coordinate systems and their unit vectors (er and eθ)
  • Basic knowledge of differential equations and their applications in physics
  • Concept of small-angle approximation (sinθ ≈ θ)
  • Study the derivation of motion equations in polar coordinates for oscillatory systems
  • Learn about the implications of small-angle approximations in pendulum dynamics
  • Explore the relationship between angular displacement and linear motion in circular paths
  • Investigate the role of tension in pendulum motion and its mathematical representation
Students of physics, particularly those studying mechanics and oscillatory motion, as well as educators looking for effective methods to teach polar coordinates in dynamics.
mkerikss
A pendulum consists of a particle of the mass m and a thread of the length l (we don't consider the threads mass). The acceleration caused by gravity is g. Solve the particles displacement and the force caused by the tension in the thread T in a polar coordinate system. The pendulums oscillations are of small amplitude. What is the period of the particle?
NII: \sumF=ma
sin\theta=\theta
T=2\pi\sqrt{}(l/g)
First of all I'd like to introduce myself. My name is Mikael, and I have recently started studying at Helsinki University of Technology. One thing that causes me a fair bit of difficulties is that Swedish is my native language, and all the lessons are in Finnish. I read the most advanced physics and maths courses the University offer, and it's been quite tough. Now here's my attempt at a solution:
I started by drawing a picture with all the forces and the components where needed, in this case I chose to keep T and divided mg into mgsin\theta in the direction of x and mgcos\theta in the direction of y. I applied NII so that
-mgsin\theta=max.
m disappears and I wrote a as seen below, which leads to
d2x/dt2=-gsin\theta.
After integrating twice I had
x3/6=-1/2*gsin\thetat2, but since
sin\theta=\theta
x=\sqrt[]{}3-3g\thetat2
At this point, I had a look at the tips and tricks one of our teachers gave us, and it looked nothing like this. He had used the vectors r and e\varphi, and lots of dots above them, that I don't even know what they mean. I started to think that maybe the polar coordinate system means I must write the answers with these vectors, but I have no idea how to do that, because the tips made no sense to me at all. Therefore, what I first of all want to know, is wath is the correct way to give the answer. Can I do as I have done, or is it completely wrong. If I'm wrong I appreciate all help because I'm not even sure what a polar coordinate system is. So some help to get me started would be great in that case. Thank you for your time!
Hi mkerikss! :smile:
(have a theta: θ and a phi: φ and a pi: π and a square-root: √ and a sigma: ∑ :wink:)
mkerikss said:
… Solve the particles displacement and the force caused by the tension in the thread T in a polar coordinate system.
(dots are the same as dashes … they mean d/dt :wink:)
The question asks you to use a polar coordinate system …
so position is (r,θ), and velocity is measured along the local directions er and eθ
er is the unit vector along the r direction, and eθ is the unit vector perpendicular to er, in the direction of increasing θ.
Also, (er)' = θ'eθ, and (eθ)' = -θ'er
Then, for example, r = rer, and so r' = rθ'eθ, and r'' = … ? :smile:
Polar coordinates:
http://en.wikipedia.org/wiki/Polar_coordinate_system"
instead of x and y you use r: distance from origin and \phi angle from a fixed direction.
you use this with problems that deal with rotation. problems will often be easier when converted to polar coordinates
In the case of a pendulum, r always the length of the pendulum, so you only have to deal with a differential equation for phi. phi =0 corresponds to straight down.
you have to split the force of gravity on the particle in a component in the direction of the origin (the r direction) and a component in the direction tangential to the arc that the particle makes. Only this component works in the phi direction. you get
F_{tangential} = m r \frac {d^2\phi} {dt^2}
instead of F=ma
Thanks for all the help, I'll give it another try. At least now I understand what it's all about :smile:
