Pendulum problem: Horizontal force and work done
The discussion revolves around calculating the work done by various forces acting on a simple pendulum with a mass at the end. For part a, the user derives that the work done by the horizontal force F can be expressed as W = mglTan(θ)sin(θ). They correctly note that the tension force Ft does no work since its direction is always perpendicular to the mass's motion. The user seeks confirmation on their calculations and guidance on determining the work done by the gravitational force Fg. The analysis emphasizes breaking down the forces into components to solve the problem effectively.
DukeJP2010
A simple pendulum (sting has no mass, no air resistance) has a weight on the end of mass m (unknown). The string has a length A horizontal (and always horizontal) force, F, acts on the weight, but it moves so slowly that acceleration is 0.
a)What is the work done by force F?
b)What is the work done by Fg (Fg=mg)? What is the work done by Ft (tension in the string)?
Work = Fd
Here is my attempt at part a. If i am right with a, then i can do 1/2 of b (the mg part) and will attempt Ft after that.
First, break it down into the X and Y components.
Y: FtCos(\theta)-mg=0
X: F-FtSin(\theta)=0
use the Y equation to solve for Ft:
FtCos(\theta)-mg=0
FtCos(\theta)=mg
Ft=mg/(Cos(\theta))
plug Ft into the X equation:
F-FtSin(\theta)=0
F-[mgSin(\theta)]/(Cos(\theta))=0
F=mgtan(\theta)
Now that we got an equation for force, we need to find the distance that the mass moves in the X direction, which is:
dx=lSin(\theta)
so, plug this into W=Fd and get:
W=[mgtan(\theta)][lsin(\theta)]
W=mglTan(\theta)sin(\theta)
Does this look right? If it is right, do pretty much the same thing for Fg. Any clues for work done by Ft?
Ok, since the direction of travel of the mass is always perpendicular to Ft, then Ft can't do any work.
Does the rest of it look OK?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
