Xidike
- 72
- 0
How compass detect the Earth’s natural magnetic fields, to tell the direction ??
Xidike said:How compass detect the Earth’s natural magnetic fields, to tell the direction ??
Then why the north pole of Earth and north pole of Magnet Does not repel each other.. ?Drakkith said:The same way two magnets detect each other.
Xidike said:Then why the north pole of Earth and north pole of Magnet Does not repel each other.. ?
Xidike said:I tried but it does not work for me..
CWatters said:Rather a lot of people have managed to get it to work including my five year old children.
There is a photo here of the device used to demonstrate the effect..
http://upload.wikimedia.org/wikipedia/commons/5/59/Plastic-compass.jpg
"Iron" refers to the elemental metal, as opposed to an alloy or oxide. Authentic, pure iron will not become permanently magnetised under any circumstances. "Steel" refers to a large variety of alloys of iron, the most common being iron/carbon.sophiecentaur said:OK. 'Soft Iron' has very low remanence and makes a very poor permanent magnet. It is also very easily magnetised whist the applied field is there. Perfect when you want to control the magnetic field (solenoid in a starter motor etc. or a relay). Steel is harder to magnetise and will remain magnetised. The right grade of steel of other ferromagnetic alloy is even harder to magnetise and will stay magnetised for longer (impervious to being bashed, for instance).
I don't think Wiki and I disagree, do we? The general term 'iron' doesn't always refer to soft iron but to cast iron, for instanceor 'iron age tools' - which have a higher remanence. You would have found that out if you had read around more, I am certain.
Xidike said:They Does not repel.. rather the needle of compass reverses the direction..
Drakkith said:Well, technically it doesn't matter. However an AC current will alternate the polarity at the frequency of the circuit. So all electromagnets used actually as a magnet to pick up stuff will be DC.
http://en.wikipedia.org/wiki/Electromagnet
zoobyshoe said:The steels will not become permanently magnetized unless they have been hardened. That's an important point. It is quite possible to rub a piece of soft steel with a magnet or place it in a magnetic field without it becoming permanently magnetized. Tools like screwdrivers and wrenches pick up permanent magnetism very easily because they have been hardened to make them more durable. Motor stators and rotors, on the other hand, are all made of soft steels which do not become permanently magnetized.
Whether or not the steel has been hardened is the make or break condition for turning it into a permanent magnet.
This is the case, yes. Nails have been "work hardened" to some degree when the steel wire is taken off the spool, straightened, cut, and the head is formed. You could get a better magnet by completely work hardening a nail by banging down the whole length of it with a hammer on an anvil. This recipe of steel, though, is not intended to be hardened or magnetized, so it will be a poor quality compared to any recipe intended for hardening.sophiecentaur said:I know that steel nails seem to have some remenance (they stay magnetised - for a while, at least) and that many 'steels' cannot be hardened to a useful degree.
Yes. A totally "soft" steel probably doesn't exist.Are we just talking in terms of a continuum of 'hardness', partly due to the mix and also to the heat treatment?
Right. "Tool steel" has been made according to some specific recipe for the job in question and the heating and quenching to harden it usually has to be tightly controlled for that specific alloy.It isn't every steel that can be 'tool-hardened', I'm sure - take 'angle iron', for instance.
They developed a special steel alloy for transformers, etc. (It is heat treated to make the crystals larger, but not to harden it.)I always assumed that transformer laminations were soft iron. Is that true?
Yes. A lot of literature refers to a "soft iron core" being the proper one for electromagnets. I think what they're mainly trying to get across is that the core has to be 'iron based' and should not be hardened. I'm not sure that anyone ever actually produces pure iron for any practical applications because...sophiecentaur said:Thanks for that info. A comprehensive set of answers. The term 'soft iron' seems to be a bit like 'cast iron' in that neither is pure iron - they're just called 'iron'.
Pure iron is soft (softer than aluminium), but is unobtainable by smelting. The material is significantly hardened and strengthened by impurities from the smelting process, such as carbon. A certain proportion of carbon (between 0.2% and 2.1%) produces steel, which may be up to 1000 times harder than pure iron.
sophiecentaur said:Did you ever look at diagrams of the Earth's magnetic field? Have you connected this with other pictures and descriptions of magnets?
lasily said:A permanent magnet is the one whose electronic domains are aligned in a particular direction as opposed to the iron in which they are scattered and multi-directional. To make a permanent magnet, you can induce magnetism by keepin in close proximity to a magnetic bar or in a magnetic field.
An electromagnet is the one in which magnetic power is induced through electricity. They find applications in generators. Normal magnets do not need any electricity for their magnetism.
Have you read anything at[/PLAIN] this level yet?Xidike said:What is meant by Electronic Domains ?
Xidike said:What is the direction of Earth magnetic force ?? Vertically Or Horizontally ??
