Permanent Magnet vs. Electromagnet: What's the Difference?
122 replies · 21K views · last reply
If Earth's North pole And Magnet North pole can repel each other, then why does not the magnet become suspended in the air due to it's own and Earth repulsion force... ?
Try suspending the planet above a magnet! You just need suitable strong magnet..
http://www.gadgetvenue.com/levitating-spinning-globe-07201554/
Youtube video
I'm not asking about globe.. I'm just asking about a magnet..
Why don't try thinking (in conjunction with reading around) instead of asking?
Troll alert! Dude is 20 Years old according to his profile.
I third that motion
its just becoming very tiring trying to help someone who apparently doesn't seem to want to help him/herself
Mods, please do the honor
Dave
How can you say that I myself can't want to learn ? Mein learn he to kar raha hon..
Why Does the needle of Compass always points towards the North pole ?
because the other end always points to the south pole ... ;)
Dave
Which way should it point? Is there something wrong?
Same sign repulsion and different sign attraction doesn't explain WHY.
That can be the main problem here. No one is giving a nice answer.
A nice Mechanistic would ask for a mechanic model that can explain magnet properties. Instead of that Magnetic phenomena are explain as a quasi magic force.
When a magnet is broken into pieces, each piece is found to be a magnet with two poles.
N===============S
N======S N======S
Why Does this Happens If We Broke Only South Pole then Why Does it is Automatically Converted To Both South And North Pole ?
In 100+ posts there have been 'nice answers', 'easy answers', 'academic answers' and others. Unfortunately none has proved to be satisfactory.
In as far as it can't be explained without resorting to a force which cannot be seen then it could be looked upon as "quasi magic". There is not a 'mechanical' answer to the question any more than there is a 'mechanical' answer to why this table is solid. Why expect things to have answers that are easy and accurate at the same time?
N===============S
N======S N======S
N===============S
N======S N======S
You can view the top single bar magnet as made up of lots and lots of tiny small magnets
creating an overall large bar magnet
D
D
How does the tiny small magnets form north pole at one end and the same tiny small magnets form south pole at other end ? Very odd .. huh..
nope, not odd at all.
the individual "particles" of iron that make up the magnet each have their own magnetic dipoles ( N and S) that when all combined and all aligned the same way, make up an overall larger magnet
and to answer your other Q about heat.
Excessive heat ( when the Curie Point) is reached, that alignment gets disrupted and the magnetic field can be weakened or even totally destroyed.
Dave
It's "very odd" that you are still asking these questions. I can hardly believe Xidike is real. You are failing the Turing test, I think.
Dave
minor nitpick: the Curie point is a phase transition same as boiling or freezing. Its either all ferromagnetic, or its not.
Phase transitions are at a fixed temperature for pure substances but, in many mixtures, the transition can be over a wide range of temperatures - consider what happens in engine coolant mixtures. I would expect the same to apply to magnetic materials.
sophiecentaur said:
Yes. When they vibrate at optical frequencies.
yup or indirectly when you place a bar magnet under a sheet of paper and sprinkle iron filings over the paper they will display the field lines :)
Dave
PS thanks for the backup, sophiecentaur
I've given up on giving sensible answers. Looking at this guy's personal profile, I would suspect he's playing with an AI program for his contributions to this thread. He'll be asking whether magnetism ever affected your relations with your Mother next.
if a conductor is placed in magnetic field then How can magnet cause the flow of current in that conductor ?
