Permutations (with repetitions) problem
The discussion centers on calculating the number of ways to assign 6 jobs to 5 people, ensuring each person has at least one job. The correct approach involves using the formula 4! * nCr(6,2), resulting in 360 arrangements. The initial incorrect method, which calculated 600 arrangements, failed to account for the condition that two jobs could be assigned to the same person. Key insights include the importance of distinguishing between permutations and combinations in this context.
  • Understanding of permutations and combinations
  • Familiarity with factorial notation (n!)
  • Knowledge of the binomial coefficient, nCr
  • Basic problem-solving skills in combinatorial mathematics
  • Study the principles of permutations without repetition
  • Learn about combinations and the binomial theorem
  • Explore advanced counting techniques in combinatorial mathematics
  • Practice similar assignment problems with varying numbers of jobs and people
Students studying combinatorial mathematics, educators teaching probability and statistics, and anyone interested in solving assignment problems in discrete mathematics.
NatFex
Moved from a technical forum, so homework template missing
[/B]
The question is phrased in the following way:
There are 6 jobs to be assigned to 5 people. Each job is assigned only to one person, and each person must have at least one job. How many different arrangements are there?
In general, I would approach a selection of k objects from a total of n in the following way:
Permutations without repetition: n!/(n-k)!
Permutations with repetition: nk
Combinations without repetition: n!/((n-k)!k!) – I express this as nCr(n,k) below.
Given those conditions, then it stands to reason that 4 people will have 1 job and someone will have 2.
I approached the problem by thinking about the number of possible employees for every job then multiplying it all out:
Job 1: 5 (all of them)
Job 2: 4
Job 3: 3
Job 4: 2
Job 5: 1
Job 6: 5 (allocated to someone who also did another job above)
5*4*3*2*1*5 = 5! * 5 = 600
This seemed to me like it should logically work. The job numbering is obviously arbitrary so this should take into account any assortment/ordering
However, the correct answer turned out to be 4! * nCr(6,2) = 360. The reasoning behind this revolves around splitting the problem into the first 4 jobs (hence the 4!), then, for the last 2 jobs, working out how many ways there are to select 2 jobs out of 6 for 1 person to do (hence 6 choose 2.)
This makes a little bit of sense, but not as much as my initially proposed solution. Can someone explain exactly where this succeeds and where mine falls short? Why is my number larger? What are the 'excess' possibilities it's counting? Thanks
The problem with your counting method is that jobs 1 & 2 could be done by the same person.
That said, I don't agree with the "correct" answer.
Does it really matter if I arranged it as 5*4*3*2*1*5 or 5*5*4*3*2*1? (In the case of the latter, jobs 1 & 2 can be done by the same person, but given that multiplication is commutative and that, as I've said, the job numbering is arbitrary, does it make a difference?)
I would like to see your take on the correct answer, if you don't mind.
Thanks
Thanks
I would do it for 3 jobs and 2 people. It's easy to count them all. Then you can check whether your formula works.
Indeed it doesn't! Formula yields 4 whereas there are 6 countable solutions. However, all I'm alerted to is the fact that I'm wrong and not how/why. I realize this is much to ask, so any input is appreciated.
You must label the jobs and the people before you start. Then, you exclude the option of jobs 1 & 2 being done by the same person.
To help you, my starting point was to think that one person must do 2 jobs and the other 4 people must do 1 job each.
