Perpendicular Plane to Two Given Planes
The original poster attempts to find a plane that is perpendicular to two given planes defined by the equations X+Y=3 and X+2Y-Z=4. The problem involves vector operations, specifically the cross product of the normal vectors of the two planes.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the calculation of the cross product and its components, questioning the correctness of their results and the presence of absolute values in the calculations. There are attempts to clarify the steps taken in the cross product and the implications of sign changes in the resulting vector.
Participants are actively engaging in the calculation process, with some providing corrections and clarifications regarding the cross product. There is recognition of multiple valid representations of the normal vector, and the discussion is exploring the implications of sign changes on the equation of the plane.
Some participants express uncertainty about the use of absolute values in the context of the cross product, indicating a potential misunderstanding of the mathematical operations involved. The discussion reflects a focus on ensuring accurate calculations and interpretations of the problem setup.
andorrak
Find a plane perpendicular to the two planes, X+Y=3 and X+2y-z=4
I know i take the cross product of both so i get
<1,1,0> and <1,2,-1>
But when i do the cross product i get x-y+z
book tells me x-y-z
what am i doing wrong? Not sure why the z is negative. The cross product formula tells me. that the only the J component is negative. (Using Rogawskis Multivariable book. Page. 698, 13.4.)
The book is right. Your cross product must be wrong. Can you show how you got it?
This is what i did.
|i j k |
|1 1 0|
|1 2 -1| =
*simplified*
|-1-0|i-|-1-0|j+|2-1|k
which gives me
i - j +k
andorrak said:
This is what i did.
|i j k |
|1 1 0|
|1 2 -1| =
*simplified*
which gives me
i - j +k
There's some mistakes in there alright. Take the i component. I get the coefficient to be 1*(-1)-0*2=(-1). Check your examples again.
andorrak said:
This is what i did.
|i j k |
|1 1 0|
|1 2 -1| =
*simplified*
Are those really absolute value operations you're doing there? If so, they don't belong in the calculation.
I thought that there were supposed to be absolute values in the equation.
If there are not, the way i would calculate it would be then:
-i + j + k
-i + j + k
Now that's right! Thanks for picking up on the problem, dynamicsolo.
No, they shouldn't be there.
-i + j + k
Much better. You now have the direction vector for a line mutually perpendicular to the two given planes and thus the normal vector to the plane you seek. You next need to find a point that lies in that plane in order to write its equation.
Okay so i just used (2, 1, 0) final equation -x+y+z=-1
but the book is saying x-y-z=f
I guess they just wanted the normal but why -y-z?
Is it something as simple as multiplying by -1? if so, i feel stupid. but thanks on the absolute values, that would have been a face palm if i hadn't known that on the test day.
There is no single way to write the normal vector for a plane. Any non-zero scalar (numerical) multiple of the vector will serve; multiplying by a negative number changes the signs of all the components, but that just gives you a vector which points in exactly the opposite direction along the same line.
So you may use < -1, 1, 1 > or < 1, -1, -1 > (or, heck, < 2011, -2011, -2011 > , were you so inclined) to represent a normal vector to the desired plane. Flipping the signs on the equation for the plane (or multiplying the equation by any non-zero real number) just gives another name for the same plane, since the set of points that satisfy the algebraic equation will remain unchanged.
Yea i figured that. Thanks so much Dick and Dynamicsolo! Don't worry ill be back. lol
  • · Replies 21 ·
