PH - really basic, I know, but I'm tired
  • Thread starter Thread starter CasanovaFrankenstein
    Ph
The discussion centers on calculating the pH of a buffer solution containing 10 g of sodium carbonate (Na2CO3) and 10 g of sodium bicarbonate (NaHCO3) dissolved in 0.25 mL of water. The correct approach involves using the Henderson-Hasselbalch equation, considering the concentrations of bicarbonate and carbonate ions. The final pH calculated is 10.71, derived from the ratio of the concentrations of carbonate and bicarbonate ions and the pKa value of carbonic acid (10.25).
  • Understanding of buffer solutions and their components
  • Familiarity with the Henderson-Hasselbalch equation
  • Knowledge of molar mass calculations and concentration conversions
  • Basic principles of acid-base chemistry
  • Study the Henderson-Hasselbalch equation in detail
  • Learn about buffer capacity and its applications in chemistry
  • Explore the properties and uses of sodium carbonate and sodium bicarbonate
  • Investigate the concept of pKa and its significance in acid-base equilibria
Chemistry students, laboratory technicians, and professionals involved in chemical analysis and buffer solution preparation will benefit from this discussion.
pH -- really basic, I know, but I'm tired
Hi Chem masters out there,
Anyone want to help me with this one?
What is the pH of a solution with 10 g of sodium carbonate and 10 g of sodium bicaronate dissolved in enough water to make 0.25 mL of solution?
Chemistry news on Phys.org
Sodium Carbonate = Na_2CO_3
Sodium Bicarbonate = NaHCO_3
0.25 mL = 0.0025L
You can ignore the Na+ ion because it's neutral, and the sodium bicarbonate releases the H proton into solution whih results in the hydronium ion being formed, therefore the concentration of the sodium bicarbonate will be equal to the concentration of the H+ ion.
Concentration of sodium bicarbonate:
10g
molar mass = 84.01 g/mol
to get moles, take grams and divide it by molar mass:
moles of sodium bicarbonate:
1.2 times 10^{-1}
divide the moles over litres of solution to get concentration:
47.6 M? okay that can't be right =/
Then you're supposed to -log(x) that to get the pH.
In case of a base, get the pOH then 14 - pOH to get pH.
I think I did something wrong. Maybe my chemical formula is wrong? I think it might form OH- actually =(
I'm sorry!
Borek said:
This is the buffer solution, so the final volume doesn't count. Calculate number of moles of both compounds and put them into HH equation.
pKa2 for carbonic acid is 10.25.
Borek
*gasps*
I'm stupid =(
just in case "HH" is the henderson hasselbach equation.
Note that 10g represents the whole ionic compound, you'll need to first find the molar mass of each compound, then convert 10g to moles. Then you'll need to use the stoichiometric ratio (which may be 1:1, you should figure it out), to find the moles of each anionic component and divide each value by the volume. Remember to use the correct units.
Thanks Guys! That was fast and easy
0.25 mL = 0.0025L
10g
1.2 times 10^{-1}
I'm sorry!
I like the way you solved it lol, you have to incorporate the weakacid equilibrium constant..
HCO3- => H+ + CO3^2- with Ka2 of 1.5 x 10^-11
you have (10.g)/(84.0g/mol NaHCO3) = .12mol HCO3-
and have (10.g)/(106.0g/mol Na2CO3) = .094mol CO3^2-
.12mol HCO3- / .00025L = 480M
.094mol CO3^2- / .00025L = 376M
Using Henderson-Hasselbalch Equation.. pH = pKa + log( [CO3^2-]/[HCO3-] )
you get.. pH = -log(1.5E-11) +log(376M/480M) assuming 376+x/480-x ~= 376/480.
so you will get: pH = 10.82 - .106 = 10.71 thus pH=10.71
if you don't understand something i did, tell me :p
  • · Replies 21 ·
9K
19K
