Phasor Mesh Current-what am I doing wrong?
  • Thread starter Thread starter teh_dude
    Mesh Phasor
6 replies · 4K views
teh_dude
Phasor Mesh Current--what am I doing wrong??
Circuit diagram:
Calculate the phasor mesh currents, I1 and I2.
KVL/Mesh Current analysis with phasors/complex numbers.
Mesh 1: (-550@0deg) + j75(I1) + 30(I1 - I2) - j40(I1) - j24(I2) = 0
Mesh 2: (600@-30deg) + 30(I2 - I1) + j50(I2) + 80(I2) - j24(I1) = 0
(30 + j35)I1 - (30 + j24)I2 = 550
-(30 + j24)I1 + (110 + j50)I2 = (-600@-30deg)
I got:
I1 = (9.45503221553 @ -38.8333374187 degrees) A
I2 = (2.79176352576 @ 93.1719060416 degrees) A
This problem was even demonstrated in class. Yet the homework site keeps telling me I'm wrong. I don't see where I've made a mistake...?
Maybe check that the signs of the mutual inductance terms respect the dot notation and choice of loop current directions?
rude man said:
How did you incorporate the 600V at -30 degrees in your equations? You didn't show us that, so we can't find your mistake for you, if there is one.
How else can I demonstrate? It's there.
If you mean how did I mix polar notation with rectangular notation, I punched it all into the TI-89, in which the modes were set to degree, polar, and approximate.
Otherwise, I don't know what you're getting at.
I don't entirely understand how to deal with the polarity marks, but I've tried switching plus and minus for the j24Ω term. It's my understanding that they should both be -j24Ω, multiplied by I1 or I2 respectively, but I've tried both minus, both plus, one minus, one plus, the other way around, and none of the answers are correct.
I've taken a closer look at your circuit and I believe that you have them correctly oriented. Sorry for the bother.
The idea is that a positively increasing current flowing into one coil at its dot produces a positive polarity of induced voltage at the dot of the second coil. So you have to be attentive as to whether a positive increase in the mesh current will create a positive increase in the current flowing into the coil dot, or whether it will in fact cause a decrease.
That is not a viable equation. You must transform the "600V@-30deg" the same way you transform components. Example: you didn't write "wL@+90deg" for the inductive impedance, did you? You wrorte jwL. jwL is the transform of wL@+90deg. Do the same for the 600V@-30 deg. I don't know what your TI-59 is doing & I can't guess.
I checked & your mutual inductance polarities are correct and in fact your equations are correct, except the second equation is not an equation. :frown:
