Photodiode current limiting for opamp transimpedance amplifier
  • Thread starter Thread starter Dheeraj12
    Converter
20 replies · 4K views · last reply
Dheeraj12
Hi all,
I need to convert i to v using photodiode and iv converter, now the photodiode can give reverse light current upto micro amps and to convert it to volt i am using opamp with has max input bias current of about nano amps , now how can i convert this micro amps to nano amps because it should not destroy my opamp , can you please suggest a current limiter circuit so that my voltage remains the same
I am afraid, you are confused regarding the currents.
It is the INPUT current into the opamp which is in the nano-ampere range.
Hower, this can be neglected using an opamp in the classical I-V converter arrangement.
Do you know how such a circuit (with feedback) looks like?
Y
Yeah, but i am using an inverting ckt theonly issue is regarding e currentthat into the inv terminal , will current in microamps damage the opamp
Oh thanks... Just got that thanks.. Thank you sir
Ok so the current goes via feedback and maintains a voltage level vo and keeps non inv at thesame level... So it does not goto inverting terminal... Right,, sir
Can I suggest you post your circuit diagram.
I agree with CWatters, it's awkward to give a useful answer without knowing which components you are using and where they sit in your circuit.
I think, if you are using an appropriate op-amp for your purpose, the bigger concern would be in handling noise to get a useful response from your monitor.
Circuit schematic from a simulation software screen: a 741 op-amp U1 with potentiometers RV1 and RV3 (100k), a light-dependent resistor LDR1 labelled TORCH_LDR, potentiometer RV2 (100k), battery B1 (-15v), a voltmeter labelled Volts, and supply rails +12v and -12v.
Dheeraj12 said:
Hi all,
The circuit schematic you posted does not use a photodiode...
Well i used an ldristead of photodiode to illustrate that, since my simulator didnt have the phtodiode
That's a completely different circuit than the one you were asking about. Just find an example circuit using Google Images and post that instead so we can discuss it. :smile:
Dheeraj12 said:
Thank you sir
You are welcome, but you didn't answer my question. I understand that the language translation issue is a problem, but we should still be able to help you if you would ask a clear question based on that simplified schematic. :smile:
You can also use the schematic berkeman posted with an LED however the output will likely be lower than a purpose built photodiode. Single supply operation is possible if you apply an appropriate voltage to the non-inverting input.
BoB
Well,my issue was the current entering into the the inverting terminal of opamp exceeding the specified limit, but later on found out that most of the current went thro the feedback R , and the current entering invl was only nano amps
For voltage feedback op amps you don't want to rely on the exact value of the input bias current as this is a parasitic. You want to design your circuit so that the bias current is either insignificant or you compensate for it somehow.
BoB
That's correct, you have discovered a main rule of Op-Amp circuits
In an ideal/near idea situation no current flows into or out of the inputs of an op-amp
have a look at this great video from Dave @ EEV-blog
http://www.bing.com/videos/search?q...950D0C45487CFCBDAEFE950D0C45487CFC&FORM=VIRE1I have posted this link a number of times over the years :smile:
cheers
Dave
I think you misunderstand this parameter. Its not a limit you must comply with. Its a limit that the manufacturer of the op amp has designed it to achieve. Eg the op amp is guaranteed not to let more than this much current flow into the inputs.
