Photon Acceleration: Speed, Mass & Emission
  • Context: Graduate
  • Thread starter Thread starter sinebar
    Acceleration Photon
11 replies · 4K views
sinebar
When a photon is emitted from a particle, is it traveling at the speed of light upon being emmited or does it have to accerate from a zero velocity to the speed of light? If it starts out from zero velocity does it have rest mass?
Photons always travel at c in a vacuum. So, no. They don't accelerate. They are traveling at the speed of light from the moment they are emitted.
And no, a photon has no rest mass. This is why it travels at speed c, and also why it must travel at speed c.
In refraction, what causes the change of direction and speed of the photon? This speed change is also discontinuous, right?
A moment indicates some passage of time. So doesn't it take some amount of time to emitt the photon? There must be a transition between being emitted and actually emitted and if there is such a transition then is the photon moving at C during the transition? Does the Photon go from zero velocity to C absolutely instantaneously with zero passage of time? the photon must at some point in its life be at zero velocity. Right?
No. Why "must" it have zero velocity? There is no physical reason I can think of, your preconception is not a physical reason.
First, photons mediate the electromagnetic force, as far as I know there is no force that acts on photons, therefore there is nothing that could accelerate them.
Second, photons are massless, so if they have any v<c they don't exist.
Third, if they don't begin at c then energy and momentum (i.e. four-momentum) are not conserved.
Those are all physical reasons that they don't accelerate. I urge you to put aside your preconceptions.
Ok so at no point in the life of a photon does it ever have zero velocity? Even at the absolute instance of creation it is traveling at C? In other words a photon has never been at rest? If it has never been at rest then there must be absolutely no passage of time from creation to C?
Photons always travel at C irrespective of the medium through which light is travelling. What is seen as refraction is actually the decrease or increase in the group velocity.
Special relativity requires that any massless particle always travels at C. So yes, for a photon to exist it must be traveling at C.
So the photons themselves travel at c in all mediums, but the light propagates at different speeds? Is it because some photons are absorbed or deflected, so it slows the total rate at which the light moves through the medium? I'm not too familiar with a lot of optics, so maybe I'm completely wrong.
Correct. Otherwise it would violate all sorts of conservation laws.
Correct.
Whilst this analogy is commonly used to explain this phenomenon it isn't an accurate description of the process. Perhaps the FAQ https://www.physicsforums.com/showpost.php?p=899393&postcount=4" may help.
Oh I see. So my thinking was basically correct, except that the photons are absorbed by vibrations in the lattice structure and not the atoms themselves. Thanks a lot.
