How Does Lead Attenuate 0.5 MeV Photons Over 1.3 cm?
The discussion focuses on calculating the fraction of 0.5 MeV photons absorbed after passing through 1.3 cm of lead, utilizing the linear attenuation coefficient of lead, which is 0.5 cm-1. The formula used is I = I0e-ut, leading to an incorrect initial calculation of the fraction as 3/5. The correct calculation yields a fraction of approximately 0.52, highlighting lead's effectiveness as a shielding material due to its high density and atomic number.
  • Understanding of linear attenuation coefficients
  • Familiarity with exponential decay equations
  • Knowledge of photon interactions with matter
  • Basic concepts of radiation shielding materials
  • Study the derivation and application of the exponential attenuation formula
  • Research the properties of lead as a radiation shielding material
  • Explore the concept of linear attenuation coefficients for different materials
  • Investigate photon energy levels and their interactions with various substances
Students in physics or engineering, radiation safety professionals, and anyone involved in materials science or radiation shielding applications will benefit from this discussion.
tastytau
Calculate the fraction of photons absorbed from an attenuated beam of 0.5 MeV photons after it has gone through 1.3 cm of lead? The linear attenuation coefficient of lead for 0.5 MeV photons is 0.5 cm-1. Why is lead a good choice as a material for shielding?
I = I0e-ut
[/B]
I = 0.5 MeV e-(0.5/cmx1.3cm)
I = 0.26 = 0.3 MeV
Fraction = 3/5
Lead is effective at attenuating photons because it has a high density and high atomic number. Many photons are attenuated in lead by striking atoms.
0.5 MeV is not an intensity. And something went wrong in the exponent.
Good.
What was wrong in the exponent? I have -(0.5 cm-1 x 1.3 cm)
I don't know what else to do with the information given.
##e^{-0.5\cdot 1.3} = 0.52## not 3/5. But maybe this fraction just came from too coarse rounding.
Just keep I0 as unknown intensity. You are calculating a ratio of two intensities anyway, it will cancel in this ratio.
11K
  • · Replies 21 ·
