Can a Free Electron Absorb All the Energy of a Photon?
A free electron cannot absorb all the energy of a photon due to the conservation of energy and momentum principles. The Einstein energy-momentum formula is essential in this analysis, as it relates energy and momentum before and after the interaction. To demonstrate this, one must equate the initial and final energies and momenta of the photon and electron. The discussion highlights the need to correctly apply these conservation laws to arrive at a valid conclusion. Understanding these concepts is crucial for solving the problem effectively.
Void123
Using energy and momentum conservation requirements, show that a free electron cannot absorb all the energy of a photon.
Einstein energy-momentum formula:
(E)² = (mc²)² - (cp)², where m = mass, E = energy, c = speed of light, and p = momentum vector.
I expanded this by setting the initial energies of the photon and electron equal to the final. However, I am not entirely sure what significant expression I'm supposed to be looking for here in order to answer this question.
Thanks.
Your energy equation is incorrect; the minus sign on the right side should plus. Energy conservation requires you to write
Energy before = Energy after
So you need to find expressions for the "before" and "after" energy and set them equal. Finally, you have not considered momentum conservation. This requires you to find expressions for the "before" and "after" momentum and to write
Momentum before = Momentum after
Do all this and you might be able to see where this is going.
  • · Replies 54 ·
