The Size of Photons: Experiments and Results
bassplayer142
In visible light, what is the spatial dimensions of the photon itself. I'm interested in the experiments they have done to prove how big the photon is.
In most cases, a photon is described by its wavelength and has physical properties that relate to that. Visible light is roughly in the range of 350 to 750 nanometers (10^-9 meters).
Naturally, there have been any number of experiments that connect wavelength to some of these physical properties. Is there any specific "size" property you are trying to understand? Other than wavelength, a photon does not have another parameter that relates to size in the normal sense of the word. (As a quantum particle, it is bound by the Heisenberg Uncertainty Principle. It is otherwise considered to be a point particle in much the same fashion as an electron.)
Thanks you guys. I had devised a little experiment myself. I didn't get into detail about it but basically you shine a laser against a solid object. If the size of the photon is smaller then an atom it should shine brighter in the crack where the laser and object meet and it would through the object. Of course the object would have to be ideal for the amount of light it let through also.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
