Photon Starship, energy momentum
The discussion revolves around deriving the mass ratio of a photon starship using energy-momentum conservation. The original poster struggled with formulating the problem correctly, initially misapplying energy conservation principles. They eventually reframed the scenario by considering the starship as a particle that splits into a photon and the moving spaceship. By applying conservation laws and recognizing the role of relativistic mass, they derived the correct relationship between the initial rest mass and final rest mass. The final expression shows that the mass ratio is m/M = sqrt[(1+v/c)/(1-v/c)], indicating a clearer understanding of the problem.
George231086
Hi I'm having trouble with this question and would like some kind of hint on how to proceed.
A photon starship starts from rest and propels itself by emitting photons in the direction opposite to its motion until it reaches a speed v. Use energy momentum conservation law to show that the ratio of the initial rest mass, m, to it's final rest mass M is
m/M = sqrt[(1+v/c)/(1-v/c)].
I'm not sure how to approach it, i think my formulation is wrong. I've looked at:
(Eo/c,0)=(E1/c,p)+kE3/c(1,n) where Eo is the original energy of the spaceship as measured in the initial frame, E1 the energy after and then E3 the energy of the photon. I've added a K to account for how many photons we need to get to a velocity v. However looking at this seems to give nothing. I've also used the identity E^2=E0^2+c^2p^2 to try and get something but it goes nowhere.
Essentially i know that in order to get the final rest mass i need to be in that frame and not the initial frame. I know from the initial frame the mass will be mgamma.
Overall i think my formulation is wrong and that my view of the situation is incorrect and so would like a push in the right direction.
Thanks.
Right i think I've got it, if I've fudged it or my reasoning is wrong i'd appreciate a correction.
So I've considered it as if it was a particle which has split into two, a photon and the spaceship in motion. I've taken it from the rest frame of the initial space ship. So using energy-momentum conservation we have that:
4 momentum of spaceship1= 4 momentum of spaceship2 (in motion)+4 momentum of particle.
So (E0/c,0) = (E/c,P) + (Ep/c)(1,n).
Now P=mv=Ep/c and E0=E+Ep, so E0=E+mvc which gives E=E0-mvc.
Then E=moc^2-mvc and we have that mc^2=moc^2-mvc. After rearranging this gives
(m0/m)=1+v/c but m=(gamma)*M so multiplying by gamma we get the result.
Hopefully that's fine. I think my main problem was that i was thinking as the spaceship at the beginning as the same as the one at the end, in the sense that it's rest mass should be the same. Thinking of it as a particle that has exploded seemed to help.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
